Kpro?
Rep Power: 0 Kpro?
I've been doing research on Kpro and yes i've search the forum already and only found one thread about Kpro. Okay so Kpro is gonna cost 1K and I also have to find a RSX-S ECU ($600) to even tune my car since you cant program a D17 ECU correct?
I'm not looking for boost and i'm NOT going K series. I'm looking to only run 140Hp to the wheels thats it. Thats my goal. Is it possible to get that with Kpro and some bolt on's?
I've done research on bolt on's as well I know that i'll probably only gain 10hp because our stock ECU's dont know what to do with the extra air.
For those of you who have Kpro was it worth the money? If so can you also show some Dyno results for when you got it tuned?
Alot of questions I know.
Live for the Twisties
Rep Power: 260 Re: Kpro?
Hondata is overkill if your only looking to get 140hp, you'd just be burning money that you could put towards other mods. Look into a piggy back system instead, both AEM and Greddy make them for the D17 and they will more than fill your needs.
1 Post
Rep Power: 364 Re: Kpro?
Yeah, kpro will give you a great way to tune your engine, but with basic bolt ons its not going to give you much better results then what a piggy back can... but might I add, I dont know what bolt ons your going to use to get to 140...
I would get a stage 2 or stage 3 cam and valve spring upgrade from Crower, paired with hondata kpro, and you can hit that 140 number pretty easily and still keep your car very streetable without the whole turbo hassle.
You could spend on Hondata and great cams, but looks is a factor too. With a piggy back, intake, exhaust, stage 1 cam and a tune I think you would be close to 140hp.
If you seriously want Hondata you can get a used ecu for $300.
Received 1,440 Likes
Rep Power: 338 Re: Kpro?
i believe the most bomerman19 ever got on a N/A motor in the wheels was 125WHP, and he had one of the most modified engines around...
Rep Power: 0 Re: Kpro?
On the "D17 does not suck" thread some guy on there by the name of bomerman showed dyno sheets that the crower stage 3 cam wasn't worth anything and that you lose power with it so thats a no go.
I'm looking for maybe 130-140Hp i'm not asking for much at all. The D17 is for mostly economic purposes and is a reliable DD engine I know. I just want some extra passing power.
Yeah Kpro is pretty expensive I would like to find some dyno sheets of someone that has it. So far no luck in my search. Maybe i'm not looking hard enough.
Your car and bomerman's can't be compared, they're completely different circumstances. Those cars are pushing 300-400hp, your only looking to get up to 140hp. Its easy to find dyno sheets with Kpro, I could direct you to a few of them, but none pushing the 130-140hp range because K-pro to add 10hp is major over kill.
found - not Paul, but Bryan using stage1:
That would be my old dyno number.. And I was on a heartbreak dyno
D17a1 bottom end
EX head
Crower Stage 1 cam
Injen SRI
Megan Header/cat-delete
Greddy Evo2 Cat-back
Stock ECU
D17a1 bottom end
EX head
Crower Stage 1 cam
Injen SRI
Stock ECU
wikkaco0
Engine Swaps
36
09-10-2007 09:46 AM
