Sponsored by:
Sponsored by: DashLynx
Light pop when turning/turning and braking
Old 12-01-2010
fripperiffic's Avatar
fripperiffic is an unknown quantity at this point
I just bought a used 2002 Civic EX coupe, and have noticed that when turning, and usually turning while breaking, especially within the first few minutes of starting the car, I hear a light pop, and can feel it just slightly in the break pedal. It doesn't pop pop pop, like I have heard can be symptomatic of CV joint problems, but what else could that be? The front brakes and rotors were recently replaced.
fripperiffic is offline
Old 12-01-2010
lowlife9's Avatar
Re: Light pop when turning/turning and braking
maybe ball joints,upper strut bearings.
lowlife9 is offline
Old 12-01-2010
Live for the Twisties
MindBomber's Avatar
I'd say that LCA bushings, they need to be replaced at a certain point.
Labour should be around $150, and parts between $15 and $50.
MindBomber is offline
Old 12-03-2010
popee's Avatar
popee will become famous soon enough
is your car lower??? if so you might need to reinstall your shocks/springs , or need to replace the top mount,
https://www.civicforums.com/forums/4...ises-read.html
popee is offline
Old 12-03-2010
if you are lowered, yes the stock suspension parts will take a serious beating. bushings, endlinks, etc.
gearbox is offline
Old 12-03-2010
not lowered, as far as I can tell. I don't think the previous 2 owners did any kind of mods.
Old 12-03-2010
well even so, the front LCA bushings (there are 4 total, two per side) are usually torn by 50k miles on stock suspension. they are not designed well at all and the weak rubber will tear up over time, affecting cornering and causing metal to metal noise. also can cause serious alignment issues and tire wear. i switched to the energy suspension replacement poly bushings that will pretty much outlast the car. they are stiffer and much beefier. they do sometimes squeak in cold weather, but the benefits are worth it.
gearbox is offline
Poopies
04-20-2017 11:36 PM
MamaBear2015
05-27-2015 12:04 PM
trellex
05-24-2015 04:39 PM
Ma213802
05-18-2015 07:01 AM
McD
04-29-2015 03:50 PM
Quick Reply: Light pop when turning/turning and braking
