Passenger door doesnt lock automaticaly..
Rep Power: 0 Passenger door doesnt lock automaticaly..
i got an 02 EX, n its two door, and my passenger door does not lock, and i recently discovered to lock driver door i have to pul the door handle and hit the lock button at the same time,, does anyone know why? and is there a way to fix my pass side door lock? PLEASE HELPPPPP
Re: Passenger door doesnt lock automaticaly..
The drivers door will not lock when open, normal operation on Honda.
Try working the lock/unlock button several times up & down. Look for any movement from the passenger lock **** and listen for buzzing noises or sounds from the door when attempting lock/unlock.
Rep Power: 0 Re: Passenger door doesnt lock automaticaly..
ok i flicked the lock button over and over with the key out and the passenger door did nothing,, the only thing the driverdoor did was move the lock down and then up becus i have to pull the door handle and hit the lock button at the same time to lock it,, and it made a clicking noise on the driverside when i was hitting the lock/unlock button.
The actuator is a plastic assembly mounted to the latch assembly, it contains a small DC motor and some gears. It has a small arm linked to the latch used to lock and unlock the doors.
"Actuator" is the name used, very common problem on the 7th gens.
07-12-2015 11:54 AM
beeemerdude
07-10-2015 09:22 PM
ballmich
07-09-2015 11:59 AM
jferristx
07-08-2015 10:09 PM
