Sponsored by:
Sponsored by: DashLynx
alternator / compressor belt squeal 2002 Honda Civic LX
Old 07-19-2010
silverbuffalo's Avatar
silverbuffalo is an unknown quantity at this point
What is the tension for the alternator/compressor belt on a 2002 Honda Civic LX 1.7L?
Symptoms:
1. Condition Compressor OFF: Belt quits squealing when water applied to belt grooves. (Doesn't this indicate an alignment issue?)
BUT
2. It squeals when the compressor is turned ON: (doesn't this indicate a tension problem?)
silverbuffalo is offline
Old 07-19-2010
lowlife9's Avatar
Re: alternator / compressor belt squeal 2002 Honda Civic LX
why don't you just tighten the wing nut under the alternator ???
lowlife9 is offline
Old 07-21-2010
kgflash1's Avatar
kgflash1 is an unknown quantity at this point
Squealing usually means loose. And tightening the belt will fix it. Just tighten the wing nuts like lowlife said. But be careful if the plastic on the radiator fans. I cut my hand open pretty good on them multiple times. The tension is .25 but my main drive belt is much tighter.
kgflash1 is offline
alexkharden
04-23-2015 07:13 PM
jessicakaybby
04-20-2015 12:11 PM
chgofirefighter
04-18-2015 08:08 PM
vino
11-03-2001 11:08 PM
Quick Reply: alternator / compressor belt squeal 2002 Honda Civic LX
