ATF change:drain or not?
Old 06-29-2010
Grunge101's Avatar
Grunge101 is an unknown quantity at this point
Hello.
Basically the ATF replacement in my 03 Vti Civic has been long due..i read somewhere that if the fluid gets very old and thick,one shouldnt drain it as it can screw up the gear settings...now im not sure if this is true and how am supposed to change the ATF if i cant drain the old fluid out?..
another question:can i do the ATF change safely at home?
Grunge101 is offline
Old 06-29-2010
Drenic's Avatar
Drenic is an unknown quantity at this point
Re: ATF change:drain or not?
I really think its important to change your ATF since you have a automatic I would check the levels and make that decison on your own. I would speak with a Honda service guy to check and see if that statement is true. I just changed my MTF (Manual Trans Fluid) a week ago and that was the first time it was changed it wasn't too dirty but it needed to be changed. Its alot more difficult changing the MTF over ATF but the drain plug is in the same location on both. From research on the net and a Haynes book from Pep Boys or Advance Auto you can find out how much "TF" is needed for your car. Here is a link to a Youtube video on how to do it.
http://www.youtube.com/watch?v=Tj5xTXRK9OI
Let me know if this helps.
Drenic is offline
Old 06-29-2010
lowlife9's Avatar
get it changed asap do the drain and fill yourself its just like changing the oil . also the proper way is to drain it fill it then drive it around then repeat two more times.
lowlife9 is offline
Drix
08-14-2015 11:41 AM
Q-Bert
07-19-2015 09:09 PM
07-12-2015 11:54 AM
Mike_47
Transmission
07-08-2015 02:42 PM
SteveA
10-13-2007 12:22 PM
Quick Reply: ATF change:drain or not?
