header install
Rep Power: 0 header install
took it upon myself to install a cheap ebay header since my oem header was about to fall apart..
before
heat shield removed revealing the crack, and a roasted wasp i think..
header removed, that is p.b blaster on the ground btw in case your wondering..
-edit: after driving 80 miles
all in all i think it took me about 2 hrs and 30 mins, and this is basically my first time turning a wrench on a car..
fired it up, no leaks, took it for a wot run and dont feel much difference up top, but i definitly feel a difference in the mid range.
so i am now catless, using the weapon R CEL eliminator, and so far its working fine.
so we'll see how long this cheapo header lasts, if it cracks anytime soon i guess ill just do a ex exhaust conversion since im now confident in my ability to do it myself.
before
Rep Power: 232 Re: header install
nice job but cheap headers tend to rust very quicklyi woild remove it and paint it with high heat header paint and i would get rid of that cheap air filter asap.
Whachya lookin at?
Rep Power: 289 Re: header install
Take your time, lots of thin coats with some time inbetween.. high temp spray paint. You might want to scuff it down with some fine sandpaper too so the paint sticks... high temp primer might even be a good idea too if you can find it.
Received 1,146 Likes
Rep Power: 485 Re: header install
Yours will because you've eliminated the catalytic converter. Ways around that is to do the spark plug non-fouler thing or convert to an ex exhaust setup.
edit: just read you're using a CEL eliminator.. disregard my post.. What code is it throwing?
Rep Power: 0 Re: header install
itll last. i have a similar ebay header and it's lasted for probably 2 or 3 years now. hasnt rusted at all but it did discolor from the heat.
whats this CEL eliminator and spark plug non fouler thing? sorry for so many questions, i tried searching and im still totally lost.
Whachya lookin at?
https://www.civicforums.com/forums/7...simulator.html
That's the defouler. It basically backs up the o2 sensor so it does not detect as much gases after the cat has been eliminated. Turning off your check engine light which comes on due to the o2 sensor.
with your car you can't use the defouler trivk because its to long and will hit your alternater you need to get a Angled mechanical simulater megan racing makes one for 25 bucks.
http://www.robearracing.com/pd-megan...or-cel-fix.cfm
thats the first one i bought and then found out it was to long to install with the header on the car so i didn't feel like taking it off and just ordered the megan one.
the weapon R CEL eliminator fit on my car just fine, just make sure you put it on the header before you put the header on the car. 300+ miles with it so far and no CEL ( my commute is 80 miles a day ;o )
Low and slow!
1 Post
Rep Power: 190 Re: header install
The reason why you have to get a defouler for an after market header is because the cat if it still has one is not like the oem cat. If you look into a cat all it is is a big honeycomb and where the secondary sensor is it is basically surronded by a big wall. When you take it out of that wall it will sense all of those gases just like the primary sensor which causes the check engine which is usually called o2 sensor below the threshold. When you put it in the defouler it acts just like that cat with the wall.
But a ebay header is a great replacement for a header if it cracks or anything. It is cheap rather than the oem cat which is expensive.
hey when a installed mine
ther was a error on the cluster the engine check showed up
that was only about 3 or 4 days then dessapear by his self a never came back since 3 years ago,
now our days this light came up and i scanned so the issue iis the o2 sensor, the issue was, for drivin in first gear for about 2 miles at 2500 revs, i took away the sensor and it was burned,
why driving in first gear for 2 miles, cuz my clutch master cilynder is broken, son pressure
saludos banda!
saludos banda!
Re: header install
im thinking about getting an ebay header too? who did you buy it from? did it bolt up to your stock exhaust? in have an 02 ex. im new to the scene... so can someone explain how to eliminate the cat without throwing codes all day?
a newb question in know....
you won't have any problem with throwing cel code's cuz you car is an ex, different exhaust setup. Just make sure when you search it on ebay the header your looking for is to fit an ex, not a dx or lx.
mjdiaz89
06-21-2016 09:26 PM
OptimisticWay
46
10-15-2015 02:16 PM
17
07-23-2015 11:48 PM
