Noob. 05 Civic LX
Rep Power: 0 Noob. 05 Civic LX
All right how's it going everybody. Generic noob post here.
So a few weeks ago my transmission in my 98 Mustang (not GT) finally give and I lost first gear. Possiblly second. But thats not why Im here.
My new car is a 2005 Honda Civic LX with 84K Miles.
After popping the hood it became readily apparent that this is much different than my domestic V-6.
The car is all stock. I know nothing about Honda. I'm not a racer but I do have a bit of a lead foot but with 115hp I don't expect to be flying through the streets like on NFS.
I'm looking for knowledge here. I don't have a budget, this car is gonna stay with me for a while so if its worth the investment, I'll probably pony up.
So right now at 84K is there anything pressing I should be concerned with? Car runs fine but again, I'm still getting used to the change.
Been flipping through the threads (Yes a noob that uses search =D ) and I see a lot of people saying suspenssion is the big one to upgrade. That and a turbo but that is quite a bit to start doing to a car you havent even got the plates on yet.
But before I digress too much, any pointers you can give me, maybe a nudge in the right direction, it would be appreciated.
-thx
-thx
Received 1,440 Likes
Rep Power: 338 Re: Noob. 05 Civic LX
and while at it, head gasket
If automatic, pay attention to the transmission too.
Rep Power: 232 Re: Noob. 05 Civic LX
you dont need a new head gaskit but your almost due for a transmission belt service including water pump,all belts, timing belt tensioner. also a tune up air filter,oil, transmission fluid drain and fill,and most likely a valve adjustment new plugd wouldn't hurt denso iridium work the best. also inspect your front compliance bushings make sure there ok. ow and your car only makes 90 hp to the wheels.
Whachya lookin at?
Rep Power: 288 Re: Noob. 05 Civic LX
Head gasket should last the life of the car as long as you don't overheat at and it's not defective. If you change a perfectly good working head gasket you could put in a crap one and blow it in a year or two... The install could also be screwed up causing issues, if it's not broken, don't fix it. I agree with the maintenance stuff listed above though.
I had 80k on my civic when I changed the timing belt and water pump + tensioner. The water pump and tensioner I pulled out look exactly like the one I put it., as in brand new. But I had already bought them so I just installed it anyway. I felt kind of stupid doing it... Even the guy at Honda was asking me why I'm replacing them and trying to talk me out of it... I think if they are in good shape you can leave them in there. These cars are designed to replace the tensioner every second timing belt. I still kind of have mixed feelings about it. Mostly because I live in Canada and the parts are so expensive I spent like 300 bucks on the water pump and tensioner and in the states you can get them for half that.
hunh, sorry, have read someplace to do them head gaskets too when you do the timing belt. Was planning to do it when the time comes 20k from now...
Whachya lookin at?
You might cause more trouble than anything else if your head gasket is working... They don't really have a lifespan, and should last just about forever if you take care of your car and don't let it overheat.
OK, before i even buy anything when the time comes, i will do the compression test (if nothing overheats, that is! )
Whachya lookin at?
A compression test will tell you if you are losing compression, not if your head gasket has failed. Of course there is a chance that the loss in compression is a head gasket. There is a better way to check. You have to check for exhaust gases in the cooling system. What happens is that the exhaust gas from the cylinder gets pushed past the head gasket into the water jackets, displacing coolant. They hook a thing up to the rad where the rad cap sits and it has fluid in it, if it changes color there are exhaust gases present. It's a neat little trick If it has not failed, don't fix it, that's where I stand on that.
you beat me to it, i was going to edit for the gas test right now!
if it came down to it i would probably get a bottle of that head gaskit sealent before i replaced it entirely.and you want some rep you got it .
Whachya lookin at?
^ No No No, most of the time I agree with you lowlife9 but not this time... That stuff is crap and seals a lot more than just holes in the head gasket. The water jackets are pretty small, and don't like crap like that introduced to them. You might get away with it but the less clogging agents in the cooling system the better, along with everywhere else in the engine. If you have a head gasket problem, fix it or you will have major problems later. LoL now I'm gonna make mad rep cuz i bitched
Whachya lookin at?
Oh in that case I agree. If your trying to get the last little bit out of your engine for sure. I'd rep ya back but I have to spread it around
I don't see why it would be warped unless it had some overheating going on though. If it's not too warped a machine shop car still resurface it.. If it overheated bad though it's warped beyond repair or sometimes it even cracks the head.
guys, i am not the OP... Just apologizing for saying the head gasket here...
Now get a room for yourselves
This was actually one of the first things i worried with the engine stuff after more than 90k miles, together with the timing belt and water pump and valve adjustment, without having real engine issues since all of us own honda's!
Chill down and stop harassing me! :P
I just got too upset with some guy(s) (in the other thread(s)!!!!)
to the OP, i will post in a separate post for better seriousness (I am ignoring the mustang part:P):
check here, since this will not come up first in a serach:
https://www.civicforums.com/forums/7...e-up-mods.html. most of the items should be here!: )
Whachya lookin at?
No worries... I try to get along with everyone, and I have no issues with lowlife, he is a very helpful member and without a doubt knows way more than i do about our cars..
I'm learning myself, but I just replaced the head gasket in my civic... i overheated it without being aware like a *#$@&( tool... so I know a thing or two about head gaskets.
As far as the OP goes, he probably has not even been on since his post lol
Rep Power: 0 Re: Noob. 05 Civic LX
Props to all for the lively responses. The engine is in solid shape. We got the car from a dealership and they had a lot of routine work orders (fluids and the like.) New plugs and wires sound good. Lowlife thank you for the 90hp at the wheels info lol. Good to know. Yeah I think a new HG would be overkill. Ah and quick question. I slapped a K&N filter on my mustang more for the convience than the magic powers they claim to give cars. Hype or worth it on the Civic?
Whachya lookin at?
Hype. You won't get ANY power gains whatsoever from a K&N Filter, or even a short ram or cold air intake for that matter. These engines don't respond well to bolt ons. If you want it for convenience, go for it
don't worry, i was just messing with you guys for messing with me becuase i messed up on the advice! Wow, now i am messed up in the head even more!
filter wont do anything except sound cool also i wouldn't get a K!!&N for the civic get a AEM dry flow it filters better and does not require oil which can gunk up sensors . put it this way i have a aem short ram intake megan headerwith cat delete going threw 2'25 inch piping and straight threw exhaust and i gained about 12hp if im lucky.
