Finally saved up :) ...lowering my ride :)
Rep Power: 0 Finally saved up :) ...lowering my ride :)
Hi guys, i finally saved up around $600 and decided to lower my car...
I know people posted this kind of topic before what should i get and bla bla...but i actually am gna lower it soon times...so just wanted a more realistic suggestion because well, im gna buy em
I want lowering springs for my 01 civic cause well coil-overs is just pure stiff and roads arent that bad in my area but i do bump into a bunch of bumpy roads and construction zones.
I'm getting the Wing West G5 Lip kit on it as well...so I just want to know how low should i go ? The lip kit is more or less of a mini body kit...
Here is a sample picture of the kit...and this is a sample car too...
Was thinking of 1.5 inch drop all around since i got the G5 lip kit and plus the roads bumpy, some construction, i wouldn't want to damage the lip kit...
So what should i grab, Tein S springs with which shocks? or should i get skunk 2 and go lower....or what can i do within that budget?
also,
The chamber kit, is needed so the wheels thread is same and even... right? which one? front and back ? thanks guys
(also posted this on CF ...HT...TC)
Thanks guys
also,
Thanks guys
Rep Power: 232 Re: Finally saved up :) ...lowering my ride :)
you cant say all coilovers are stiff if i was you i would keep saving for fully adjustable coil overs like progress they are very comfortable and you can order custom spring rates and shorter springs if you wanted to go lower considering there onley 900 dollars. and i would get ingalls or SPC camber kit.
Rep Power: 239 Re: Finally saved up :) ...lowering my ride :)
600$ for springs n struts, what a waste of money. Go for coilovers you won't regret it, i have had tein s tech n tokico and wow i don't miss them one bit compared to my d2's
eibach sportline, 1.4 inch drop and you can use your factory struts. They are also a quality spring.
They're not too stiff of a ride, but anytime you lower your vehicle it will change ride characteristics, typically lowering it will get more stiff so you don't bottom out while you're driving.
Rep Power: 0 Re: Finally saved up :) ...lowering my ride :)
we'll i want a ride that is not too stiff...so i heard and somewhat experienced that lowering springs and shocks i can manage for 600 - 700 bucks and they will not be as stiff and will give me the drop i want and add to my handling...
coil-overs so far, i've heard the positive that i can drop the car and change height...other than that, cant say much....
thats why i need help... tokico blues i heard of from a few people and also yellows....whats better?
and im thinking of throwing the car on 17inch rims...
gudoffer is online now Report Post Edit/Delete Message
Touge
Ottawa
08-20-2015 11:35 PM
Touge
08-20-2015 11:35 PM
Touge
07-18-2015 05:37 PM
Touge
Ottawa
07-18-2015 05:35 PM
