Rear Door Panel Removal
Rep Power: 0 Rear Door Panel Removal
Hey guys, I am new to this forum. I need to remove the left rear door panel of my 2005 honda civic lx 4 door sedan to fix a dent on the door. Can you guys point me to correct instructions or DIY for rear door panel removal ? Thanks in advance.
Rep Power: 0 Re: Rear Door Panel Removal
assuming its similar to the coupe, there should be 2 screws inside the door handle thing, just pry out the little plastic cover piece in there and a screw in the inside door handle. otherwise just pull, it's mostly pop pins that hold it in there.
If you look under the lower handle cover you will see a [_] cutout area near the fabric... carefully insert an L shaped tool or small flat blade screwdriver to relase the cover and it will peel off starting from the front, that will reveal the mentioned screws.
There is also a screw under the cover panel in the inside door handle that needs removed.
Pop plastic clips near lower edges.
Billybob1963
05-31-2015 07:37 PM
MamaBear2015
05-18-2015 07:37 PM
timpan
05-18-2015 07:06 AM
MamaBear2015
05-03-2015 02:17 PM
