Cower Stage 2 Cam
Rep Power: 213 Re: Cower Stage 2 Cam
First you need k-pro to tune it. Second, I'm assuming you mean the N/A cam. Third, you need valve springs and retainers. Fourth, I'm also assuming you already have an intake, header and exhaust.
All that being said, most numbers usually show around 140-ish with a decent tune.
Rep Power: 787 Re: Cower Stage 2 Cam
stage 2 na review
https://www.civicforums.com/forums/2...xperience.html
https://www.civicforums.com/forums/7...2-09-05-a.html
https://www.civicforums.com/forums/7...installed.html
The stage 3 has been used a few times to my knowledge, and works just fine once tuned properly. However, there are some issues with it. It's a really really aggressive cam to begin with. With the way vtec works in the d17, it can be made to idle without issue, so DD isn't an issue. The problem is that, in an N/A application, the engine doesn't have enough static compression for the cam. The stage 2 actually makes more power than the stage 3 with stock pistons. With higher compression pistons, the stage 3 should make much more power, but I've never seen anyone run this setup before. The stage 3 cam is great for high boost applications though, just because you need such an incredible amount of airflow.
ricer_em2
05-11-2016 08:09 PM
beanhead
09-24-2015 12:04 PM
OptimisticWay
09-18-2015 09:37 PM
Juanb24
09-15-2015 12:39 AM
