Sponsored by:
Sponsored by: DashLynx
Outside Door Trim Piece Removal
Old 07-02-2009
schreibers's Avatar
schreibers is an unknown quantity at this point
I got some new door moldings from Majestic today. The Bottom molding is easy enough to replace, just roll the window down and pull up then install the new one.
The molding i'm curious about is the one that lies along the same line as the B-Pillar (above the door handle) it's the side molding for lack of a better word. Just a black piece. It's held in by two clips and a screw according to the diagram but I have no idea how to get to the screw. Suggestions?
schreibers is offline
Old 07-03-2009
CraigW's Avatar
Re: Outside Door Trim Piece Removal
See if this is the part you are talking about.
File Type: pdf
CraigW is offline
Old 07-03-2009
schreibers's Avatar
Thats it man thanks!!
Old 07-03-2009
wallydude03's Avatar
wallydude03 will become famous soon enough
Do you guys know how to remove finger grease off of this molding?
wallydude03 is offline
Old 07-03-2009
CraigW's Avatar
Have you tried waxing it ?? My black mirrors take wax great (LX,unpainted) Not sure if it the same plastic or not.
CraigW is offline
Old 07-03-2009
yeah i use wax and they come out nice and shiny. or you can use meguiars trim detailer which is also good.
gearbox is offline
Old 08-16-2016
VtecYo2002's Avatar
VtecYo2002 is an unknown quantity at this point
Okay I need clarification about the "bottom molding" of the window/door frame.
I've been to the junkyard to replace ALL the window trim pieces for my gf. Anyways, I've been successful with removing one of the bottom pieces with all of the clips in tact. When I moved on to the next window, I completely busted all of the clips to get it off.
Admittedly, I didn't (wasn't able) roll down the windows to get to the trim pieces, and used a flat-head screw driver, however I'm wondering if there was some kind of "finesse" required not to ruin the parts.
VtecYo2002 is offline
numbersguy
Electrical DIY
09-15-2018 11:24 PM
drhawkinz
05-16-2015 11:39 AM
BabyLX
11-08-2001 09:25 AM
vistec
11-07-2001 05:53 PM
CivicHX01
11-02-2001 08:49 PM
Quick Reply: Outside Door Trim Piece Removal
