Sponsored by:
Sponsored by: DashLynx
o2 defouler install question
Old 05-24-2009
fiend's Avatar
fiend is an unknown quantity at this point
[/IMG]
on the o2 defouler, part with external threads screws into the header and the sensor screws into the defouler, if this is correct then what is the nut for?
fiend is offline
Old 05-24-2009
fiend's Avatar
Re: o2 defouler install question
for some reason i dunno if the pic is not posting or if i just can't see it
fiend is offline
Old 05-24-2009
fiend's Avatar
well if the picture won't post i hope yall know what i'm talkin about
fiend is offline
Old 05-24-2009
TRIZ's Avatar
Its to tighten the defouler to the bung, if you just spin the defouler around it might not point in the direction you want the wires to go, so the nut is there so you can tighten it down once you get the defouler pointed in the direction you want.
And it only goes into the manifold if you have a dx/lx manifold with the cat bungs in it... mostly it should be in the downpipe or test pipe. Read my exhaust faq.
TRIZ is offline
Old 05-24-2009
TRIZ's Avatar
TRIZ is offline
Old 05-24-2009
fiend's Avatar
thanks man...i thought i read it somewhere but i could of swore is on a different forum...explains why i couldn't find it lol, much appreciated though!
fiend is offline
Old 05-25-2009
fiend's Avatar
i looked through it but couldn't really understand what it was saying for the install...i have the megan racing angled defouler by the way. basically i screw in the defouler but leave the nut on there, that way i can angle the defouler the way it needs to be and then use the nut to tighten it down therefore leavin it in the position i want, thats what i got from reading through...hope thats right. thanks for the help
fiend is offline
Old 05-25-2009
TRIZ's Avatar
exactly. I had a headache before so maybe it didnt make sense
TRIZ is offline
Old 05-25-2009
fiend's Avatar
word, thanks man
fiend is offline
Old 02-18-2011
nelso193's Avatar
nelso193 is an unknown quantity at this point
I purchased a Megan Racing exhaust system for my 02 si and check engine light came on the same day. Drove for quit a while like this and then bought a defouler and new O2 sensor then had the check engine light reset. The next day, the car started to chug during acceleration in all gears until about 70 MPH. I bought the sensor from a dealership and defouler from civic racing I believe. What else do I need to do to reset the check engine light (it's on again) and fix my acceleration problem? I know I need to have it connected to a computer again. Thanks
nelso193 is offline
masongap
05-26-2015 07:55 PM
pincookie1
05-04-2015 12:22 PM
bsmiley
04-27-2015 01:27 PM
klam
11-16-2001 03:36 PM
Quick Reply: o2 defouler install question
