d17 swap
Rep Power: 0 d17 swap
i'm anube and wanted to kno if a d17 will swap into my 1990 civic dx?
i need a motor/trany now myn is burning oil and trany wyns. thought of a
b18a1 swap or just keep it simple w/d16 or if the d17 will work.i like the tq/hp of the d17 and my driving is hwy so i want the tq for lo-mid range.w d17 i can have the same hp/better tq than a d16y7/y8/zc and almost as much as the b18a1 w/lessweight. what is yall's ideas, any help apreciatted.
thanks
thanks
1 Post
Rep Power: 0 Re: d17 swap
dont bother with d17 it is slow and will require too much work to swap over, ur goin from single coil, to coil on plug, d16 or b18 is a much better choice
It's worth going with the B a D series build will only yield so much power unless you boost.... and thats probably gonna end up more expensive then a b18 swap... granted you'll have more power from the turbo but the swap will be cheaper and probably more guranteed to work even though it will have less HP
bolt-on-bandito
Electrical
32
01-15-2020 03:25 PM
Scout1
10-05-2015 01:33 PM
juicetayne
09-30-2015 11:02 AM
ThatGuy913
09-28-2015 05:35 PM
