HELP! 03 ex coupe d17a2 cranking but not starting
Old 03-18-2016
Bthomas1's Avatar
Bthomas1 is an unknown quantity at this point
I have read through this forum several times, I have seen similar threads on this subject but not exactly what is going on with mine.
2003 civic EX coupe d17a2,
Replaced head gasket, reset timing to TDC lined up crank and cam pulleys, Getting spark and fuel, replaced plugs, crank position sensor, idiot checked everything, fuel pump is priming good. I am going to do a compression test tonight.
But if it comes back good which I believe it will.. then I am at a total loss on what it could be...
any help would be appreciated!
Bthomas1 is offline
Old 03-18-2016
Bthomas1's Avatar
Re: HELP! 03 ex coupe d17a2 cranking but not starting
oh and I am getting no CEL codes either
Bthomas1 is offline
Old 03-18-2016
No start at all, not even trying to fire?
Forget any grounds?
Does this look familiar?
ezone is offline
Old 03-18-2016
Bthomas1's Avatar
It is turning over, misfires one time and then just turns... The grounds are sanded and in the correct places, will not even start with starter fluid..
Bthomas1 is offline
Old 03-18-2016
Bthomas1's Avatar
Thought is was flooded at one point... Took the plugs out they were a little wet. Went ahead and replaced them with ngks had autolites in originally.. No change after with throttle wide open trying to start. Like I said I have read thru many forums trying to find the answer just haven't found it yet when the compression test is done that may give me my answer.
Bthomas1 is offline
Old 03-18-2016
Wet plugs won't fire, and a flooded engine can lose enough compression that it won't fire. Need to restore the oil film to the cylinder walls so the rings can seal, and dry out the raw gas from the cylinders if possible.....
Remove plugs,
Dump about a tablespoon of oil into each cylinder.
Leave the plugs OUT.
Throw a towel over the plug holes.
Crank engine over with the starter for several seconds to distribute oil film all over cylinder walls.
Reinstall DRY plugs.
Hold gas pedal to the floor.
Crank and see if it will fire.
ezone is offline
Old 03-19-2016
Bthomas1's Avatar
I will try this! Thanks!
Bthomas1 is offline
Old 03-19-2016
Bthomas1's Avatar
Did a compression text did 90 30 30 60 I don't think flooding with lose that much compression. I'm thinking rings are a must now.
Bthomas1 is offline
Old 03-19-2016
mikey1's Avatar
those readings are way low,
are you sure your timing is correct?
sounds like you might be replacing that head gasket again.....properly this time
mikey1 is offline
Old 03-19-2016
Bthomas1's Avatar
I thought it was it was tdc and crank and cam were lined up... I could be wrong I will be doing a full rebuild on it just to make sure unless you think it could be something easier lol
Bthomas1 is offline
Old 03-19-2016
mikey1's Avatar
line up TDC on the crank, take a pic of it, and take a pic of the cam position also, post them both
mikey1 is offline
Old 03-19-2016
Bthomas1's Avatar
Ok will do
Bthomas1 is offline
Old 03-19-2016
Did you put oil in the cylinders like I suggested?
Were valve clearances adjusted when it was reassembled?
Did you ever rotate the cam or crank while the timing belt was off?
Did you set the head down flat on the floor or workbench after you pulled it off the engine?
ezone is offline
Old 03-21-2016
Bthomas1's Avatar
I haven't been able to work on it much do to working a lot of overtime. I am off tomorrow and plan to do all things suggested and post pics of timing as well.
Bthomas1 is offline
Old 03-22-2016
Bthomas1's Avatar
Timing was a little off. Haven't put back together yet, checked valve clearances they were a smidge off not any cause for concern. I'm having a second look at it then will put a little oil in cylinders and see if I have any progress.
Can't figure out how to post picture off my phone.
Bthomas1 is offline
Old 03-23-2016
mikey1's Avatar
save the picture to your computer,
at the bottom of your post under "additional options" click on "manage attachments" to upload pics
mikey1 is offline
