Sponsored by:
Sponsored by: DashLynx
Which under dash fuse gives 12V constant?
Old 09-19-2015
h4ldol's Avatar
h4ldol is an unknown quantity at this point
Question Which under dash fuse gives 12V constant?
Need some help please. I need to connect my aftermarket TPMS device to constant and ACC 12V. ACC is easy and has many sources, but which of the fuses gives 12V constant? Please don't tell me to grab my voltmeter because it's really hard to use the voltmeter where the fuse box is under/behind the steering column.
Here's where I got the pic above and the fuse list below: http://troubleshootmyvehicle.com/hon...-dash-fuse-box
2001-2005 Civic EX, DX, LX Under-Dash Fuses
# Amps Fuse Name/Description
1 15 Amps
Ignition Coil.
2 20 Amps
Air/Fuel Sensor Heater (HX; 2004: DX, LX, EX).
3 10 Amps
Daytime Running Lights.
4 10 Amps
Alternator.
A/F Sensor Relay (HX; 2004: DX, EX, LX).
Cruise Control.
ELD Unit.
EVAP Bypass Solenoid.
EVAP Canister Purge Valve.
EVAP Canister Vent Shut Valve.
Primary and Secondary Oxygen Sensors.
Vehicle Speed Sensor (VSS).
5 -- Not Used
6 7.5 Amps
Power Window Relay.
7 20 Amps
Sunroof.
8 7.5 Amps
ACC Radio.
9 10 Amps
Rear Wiper.
Side SRS (HX).
10 7.5 Amps
Meter.
A/T Reverse Relay.
Back-up Lights.
CarLink Interface Box.
Gauge Assembly.
Keyless Receiver Unit (EX; 2004: DX, LX).
Multiplex Control Unit.
Security Control Unit.
Shift Lock Solenoid.
11 7.5 Amps
ABS.
12 7.5 Amps
Daylight Running Lights (Canada).
13 10 Amps
SRS.
14 7.5 Amps
R/C Mirror.
A/C Compressor Fan Relay.
A/C Condensor Fan Relay.
Blower Motor Relay.
Heater Control Unit-Panel.
Power Mirror Actuators.
Radiator Fan Relay.
Recirculation Control Motor.
Rear Window Defogger Relay.
15 -- NOT USED
16 20 Amps
Heated Seat.
17 15 Amps
Fuel Pump.
PCM (Fuel Injection Computer).
Supplemental Restraint System (SRS) Unit.
18 15 Amps
ACC Cigar (Accessory Power Socket).
19 20 Amps
Turn Lights (Turn Signal/Hazard Relay).
20 20 Amps
Front Wiper.
Windshield Washer Motor.
Windshield Wiper Motor.
21 -- Not Used
22 20 Amps
Power Window Front Right (Passenger Side).
23 20 Amps
Power Window Front Left (Driver Side).
24 20 Amps
Power Window Left Rear (Rear Driver Side).
25 20 Amps
Power Window Right Rear (Rear Passenger Side).
h4ldol is offline
Old 09-19-2015
Re: Which under dash fuse gives 12V constant?
Use a test light instead.
Whatever your image link is, I got 403 forbidden.
Dash fuses 2, 3, 5, 7, 15, 16 are constant B+.
Slot 5 and/or 15 may be empty, should be easy to tap if they are.
ezone is offline
Old 09-20-2015
mikey1's Avatar
not positive but just by going by the items it is powering i would think #10 would be hot all the time,
like ezone said, a test light is easier then a voltmeter
mikey1 is offline
Old 09-20-2015
h4ldol's Avatar
Thanks y'all. I ended up using #3 (day lights) for constant 12V. Some intermittent power issues but it seems to be a device/wiring issue (I hope).
h4ldol is offline
Old 04-24-2017
Fo0
Fo0's Avatar
Fo0 is an unknown quantity at this point
7 20 Amps
Sunroof.
is constant?
Fo0 is offline
Old 04-24-2017
Originally Posted by Fo0
7 20 Amps
Sunroof.
is constant?
Vehicle Y/M/M?
7th gen Civic, dash fusebox, #7 should be hot all the time.
Confirm with voltmeter or test light.
ezone is offline
alaga
25
08-13-2015 04:42 PM
Dave1984
07-22-2015 06:10 PM
liagreenhalgh92
07-21-2015 01:31 PM
sam31444
ECU Fried
07-20-2015 08:31 AM
Civic65
07-19-2015 10:13 AM
Quick Reply: Which under dash fuse gives 12V constant?
