Cam position sensor.
Rep Power: 0 Re: Cam position sensor.
You are correct, took the car to auto zone, they pulled the codes but couldn't tell me what's wrong. Thought I could get some helpful info here. The car won't Rev past 4k it's like the motor is bouncing off the Rev limiter. On top of that,the idle is messed up at best. One min it idles at 1k the next it's at 2k.
he wasn't the brightest crayon in the box. I'll take it elsewhere and hope for someone a little smarter
You could just read the display yourself and write the info down or get a printout?
I've heard people mention the rev limit and long cranking time before starting, but not the idle issue you speak of. Did that start at the same time as the other problems, or is it a separate problem??
Well I have only had the car for a few months and when I first got it, it did have a little idle issue but it got much worse when the other issue began.
Rep Power: 131 Re: Cam position sensor.
I just finished putting my car back together and am getting the P1362 code which means no communication with the CPS and it idles alright but when you step on the gas the car wants to die. It also takes a bit to get the car to crank.
pilebuck13
09-21-2015 10:45 PM
Bruce2
09-21-2015 08:01 PM
OptimisticWay
09-18-2015 09:37 PM
Juanb24
09-15-2015 12:39 AM
