Sponsored by:
Sponsored by: DashLynx
New here and not sure where to start on maintenance
Old 09-17-2014
codeninja's Avatar
codeninja is an unknown quantity at this point
I have an 01 Civic LX Automatic with 220Kmiles. I do the general maintenance like tires, oil, brakes....when needed but I'm not sure what else to look for or how to look for it.
I had it tuned up around 120k miles I think and the transmission was replaced at 200K miles. I have the Hayes manual for it but don't know where to look. I'd rather not put a lot of money into it (It's paid off) but if there are other little things I can do to tune it up and increase performance, I'd like to know. I'd like to extend its life as long as I can obviously but I'm not putting anymore serious money into it.
Like for instance, how do I tell if the spark plugs need replacing? Or sensors? There are currently no error codes in the system (I have an OBD2 plug and the Torque android app).
Thanks!
codeninja is offline
Old 09-17-2014
mikey1's Avatar
Re: New here and not sure where to start on maintenance
your haynes manual and your owners manual (if you have it) both have maintanance schedules in them and tell you what is recommended at certain intervals (mileage or months/years), so that is a good general guideline to follow,
when is the last time you changed your timing belt? it is recommended every 7 years or 100k miles, if you are over those numbers then that should be your number one priority,
sensors dont normally get replaced unless they fail, if they fail your CEL will come on
stock spark plugs last a long time easy 100k miles or more, if they have never been changed then i would change them,
also throw in a new air filter and PCV valve if you cant recall the last time they were done
coolant should also be drained and filled if it hasnt been done in the last 5 years or so
mikey1 is offline
Old 09-17-2014
codeninja's Avatar
Thanks.
I'm not worried so much about air filter. I have a K&N Air Filter.
How do I tell if the spark plugs need replacement?
Old 09-17-2014
mikey1's Avatar
i normally just go by mileage,
your biggest concern should be your timing belt, if it hasn't been replaced withing 7 years 100k miles
mikey1 is offline
Old 09-17-2014
codeninja's Avatar
Thanks!
mattdoc
03-14-2017 12:10 PM
gearbox
Electrical DIY
72
11-27-2015 08:13 PM
BootyDo
05-07-2015 04:46 PM
markp94
04-30-2015 09:19 PM
black2k1vtec
12-06-2001 09:49 PM
Quick Reply: New here and not sure where to start on maintenance
