can someone help me with a sound i am hearing?
Rep Power: 0 can someone help me with a sound i am hearing?
can someone help with the sound i am hearing. i heard a weird ticking sound under load.
it was there less than a year ago. its a 2004 civic with 225,000 miles.
I had the head gasket fixed a month ago but sound was there before that. and timing belt was changed a year ago
credits Dan Ponte for his video[YOUTUBE]https://www.youtube.com/watch?v=XE3ZBqHeGHc[/YOUTUBE]
Re: can someone help me with a sound i am hearing?
Sound is exhaust leakage from the manifold.
LX: Cracked casting is very common, but could be a problem with studs and gasket leakage too.
You could probably remove the heat shields from the top of the manifold and see the crack.
Rep Power: 0 Re: can someone help me with a sound i am hearing?
someone else told me the sound could be a bad ignition timing. or loose valves.
you're absolutely right. after doing online research, i thought it was a metal sound. i went to a shop, two different people confirmed an exhaust leak and that would explain the tiny crack in my exhaust manifold and the smell of burned gas.
Kyles24
07-12-2015 09:15 PM
fvckbg
07-07-2015 07:08 PM
