Sponsored by:
Sponsored by: DashLynx
can someone help me with a sound i am hearing?
Old 07-22-2014
tallal565's Avatar
tallal565 is an unknown quantity at this point
i had my head gasket replaced 3 weeks ago and everything has been fine since.
i also had my timing belt, serpine belt and water pump changed 12 months/17,000 miles ago.
the sounds seems to be coming from the belt side, maybe tensioner.
the sound is also intermittent, especially at idle.
AC and other components work fine. just the weird sound.
thanks
2004 civic lx
[YOUTUBE]https://www.youtube.com/watch?v=RNKfyohPNgk&feature=youtu.be[/YOUTUBE]
tallal565 is offline
Old 07-22-2014
mikey1's Avatar
Re: can someone help me with a sound i am hearing?
i would not run the engine again until you have your timing area/belt inspected, you are risking serious engine damage, sounds like something in the timing area, it could be the timing belt rubbing against the timing cover
mikey1 is offline
Old 07-22-2014
Tensioner spring let go, timing belt flopping?
ezone is offline
Old 07-22-2014
*watches temp gauge like a hawkboss* :D
kinakoes2's Avatar
kinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of lightkinakoes2 is a glorious beacon of light
And Bingo was his name-o...
kinakoes2 is offline
Old 07-22-2014
tallal565's Avatar
So do you guys think its the spring within the timing belt that came loose? I only heard the sound twice today?
i got my timing belt done 11 months at 17,000 miles ago. you think they would fix it for free?
Old 07-23-2014
YOU have the car, we don't.
We're only guessing.
Remove the upper timing cover and take a look for yourself.
I wouldn't bother with that shop at all until I figured out what the true cause of the noise is.
THEN evaluate and decide what to do about it.
ezone is offline
Old 07-23-2014
mikey1's Avatar
a reputable shop would, but i have no idea where you took your car
mikey1 is offline
15EXCoupe
07-30-2015 12:59 PM
cukaracha
07-17-2015 05:48 PM
Kyles24
07-16-2015 10:14 PM
Kyles24
07-12-2015 09:15 PM
fvckbg
07-07-2015 07:08 PM
Quick Reply: can someone help me with a sound i am hearing?
