Sponsored by:
Sponsored by: DashLynx
View Poll Results: what can I do!
what do i need?
0%
did i cause this?
100.00%
Voters: 2. You may not vote on this poll
2001 will not start
Old 03-03-2014
bigbduster's Avatar
bigbduster is an unknown quantity at this point
2001 will not start
The car was running shut off and green key light started flashing! It will not start now. I had made some new keys for the trunk and doors, when the guy messed with the locks, i believe that is when the light came back on! Honda Civic LX 4door 1.7 no egr!
Need advise!
bigbduster is offline
Old 03-03-2014
Re: 2001 will not start
#1, a poll post??
#2, bust out the owners manual and see if the green key light is acting correctly or not. It is supposed to flash like 5 times after you turn the ignition off...
But does it flash while the ignition is on?
#3, locate a key that used to work and try it.
Any new keys that were made would have to have been programmed to the immobilizer system in order to start the car.
ezone is offline
Old 03-10-2014
bigbduster's Avatar
I have had a new key programmed and the car started. It ran for about 1/2 hour. That is when the lock smith was checkng the new keys in the doors. That is when I noticed the key started flashing on the consol. I shut the car off and then it would not start again. We reprogrammed the keys again, but when I try to start it turns over but will not start and the security key light still flashes. Is there a way I can by pass this feature? I have checked everythng!!!
Old 03-10-2014
JDMxES1's Avatar
JDMxES1 is an unknown quantity at this point
What was wrong with the original key? And was the reprogram done with a honda dealership or third party?
JDMxES1 is offline
Old 03-10-2014
If your locksmith (I assume?) has the ability to do the Immobilizer key programming, doesn't he also have the ability and software to troubleshoot the Immobilizer system?
Connect a scanner, see if there are engine codes?
ezone is offline
Old 03-12-2014
bigbduster's Avatar
It was done by a 3rd party and I had lost the original key so I changed the ignition switch on the steering post.
I will scan again and see what is showing.
But the car started right up after initial reprograming then after 1/2 I shut it off and would not restart.
is there a way to jump the ignition for the spark and fuel pump and bypass the anti-theft system?
Old 03-12-2014
You can't jumper it, the PCM has to see a valid input from the immobilizer control unit. If no valid input, the fuel injectors are shut down and engine will not run.
The only bypass I know of is a temporary thing....You might get your dealer or 3rd party to walk you through the "immobilizer brake code" process. Whomever got the access codes to program the immobi key ought to be able to come up with the "brake code" (I know dealers can, but I'm not sure about independents).
Other stuff:
Check
engine compartment fuses 6 and 9
dash fusebox fuse 17
Recheck everything you did, every wire you touched, mainly the 2 flat green connectors at the end of the ignition cylinder.
The 7 is the immobilizer connector, the 6 is for the light and beeper switch.
You got a used column lock - did it look cruddy, weathered? Any corrosion on the little terminals of the immobilizer unit?
Maybe.....Swap the immobilizer receiver ring from the original column lock, then reprogram the keys (PCM learn) again to recognize it?
ezone is offline
numbersguy
Electrical DIY
09-15-2018 11:24 PM
ImmortalEX
Detailing
78
09-04-2015 05:35 PM
black2k1vtec
12-06-2001 09:49 PM
supercivic01
South
11-30-2001 11:27 AM
Quick Reply: 2001 will not start
