annoying wiper problem
Rep Power: 0 annoying wiper problem
Every time i turn my wipers on the passenger side wiper always smacks the stopper and is loud(goes below the glass). And then theres times where it works normal and stops at the bottom of the glass. Any way to check it?
Rep Power: 210 Re: annoying wiper problem
Check the linkage. If that's not worn then take the arm off and look for stripped teeth. If that's not it then check for stripped teeth at the motor.
*NOTE: Be sure to mark the arm/linkage and linkage/motor junctions when taking them apart because it's a bitch to get them on the right tooth again without that mark.
ClapAlongChorus
Electrical
10-28-2021 10:50 PM
Domindart
06-04-2015 09:20 PM
autowill
05-15-2015 11:36 AM
2003, 2006, 2011, 7th, civic, civicintermittent, generation, honda, intermittent, issues, malfunction, problem, problems, relay, wiper
