Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen
Sign in using an external account
Register Forgot Password?
7th Gen In the years from 2001 to 2005 Honda released it's 7th Generation Civic. Chassis codes: EM2, ES1, EP3, EU1
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools Search this Thread
Old 01-16-2011   #1
metaliumx is an unknown quantity at this point
High-pitched noise when engine starts/accelerates
So I've got this noise, which sounds like something spinning very fast (I jokingly call it my jet engine) when I start the car (maybe whirring would be a good description). It starts out very high pitched, and then will drop in pitch as the engine warms and idles at lower rpms. While driving, it will increase in pitch as I accelerate, and then drop in pitch if I slow down or if car changes gears. Its at the shop to have the transmission looked at, but should I be asking them to check out something different for this sound?
Imagine making the sound of a car driving, but do it whistling...and that is the sound its making.
metaliumx is offline   Reply With Quote
Old 01-17-2011   #2
Sedans > Coupes
Brian1037's Avatar
Brian1037 is a jewel in the rough Brian1037 is a jewel in the rough Brian1037 is a jewel in the rough
Re: High-pitched noise when engine starts/accelerates
Happens to me too and i dont know what it is either. sounds almost electrical right? i find it most noticeable when the revs are at about 3 - 3.5k and you`re about to shift
Brian1037 is offline   Reply With Quote
Old 01-22-2011   #3
cfendley is an unknown quantity at this point
Sounds like it could be a bearing rubbing attached to one of your belts. I just had this same problem. 01 civic ex with 90k. Take one of the drive belts off. Real easy actually using the chilton's manual. If the noise doesnt stop then reattach that belt and remove the next belt. If the noise doesnt go away then you just proved your ac compressor is good, alternator is good, and power steering pump is good. All thats left is the timing belt. thats not as easy. First off if you have an amp for your stereo make sure its grounded.
cfendley is offline   Reply With Quote
Old 01-23-2011   #4
Whachya lookin at?
BlueEM2's Avatar
BlueEM2 has a reputation beyond repute BlueEM2 has a reputation beyond repute BlueEM2 has a reputation beyond repute BlueEM2 has a reputation beyond repute BlueEM2 has a reputation beyond repute BlueEM2 has a reputation beyond repute BlueEM2 has a reputation beyond repute BlueEM2 has a reputation beyond repute BlueEM2 has a reputation beyond repute BlueEM2 has a reputation beyond repute BlueEM2 has a reputation beyond repute
Dont think so WTF is twitter? Pardon? Im so confused... what box? ...
^ Good advice there... Generally high pitch noises are associated to auto tensioners. Since the only auto tensioner on our car is the timing belt tensioner hopefully its just a belt or a pulley going
__________________
2007 Ford Edge -- Stock!
2005 Honda Civic EX Coupe, almost stock!
Lower Ball Joint DIY
How to set up TDC during timing belt install
Overheating? Here is why.
Head gasket + timing belt DIY! Incomplete but useful!
With how old this forum is, if everyone searched... Nobody would post any more
BlueEM2 is offline   Reply With Quote
Old 01-23-2011   #5
2001 Civic LX Sedan
Biscuit's Avatar
Biscuit will become famous soon enough Biscuit will become famous soon enough
I am having the exact same problem with my bone stock 01 LX.
I'm looking forward to more info!
Nathan
Biscuit is offline   Reply With Quote
Old 01-23-2011   #6
Whachya lookin at?
BlueEM2's Avatar
Most likely what was said above. Try removing belts.
__________________
Old 01-23-2011   #7
Images: 178
gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute
+1 for tensioner. a worn out piece will make supercharger type sounds.
__________________
2002 Honda Civic EX Auto
gearbox is offline   Reply With Quote
Old 01-24-2011   #8
2001 Civic LX Sedan
Biscuit's Avatar
This engine does not have an auto/hydraulic tensioner.
Nathan
Old 01-24-2011   #9
Whachya lookin at?
BlueEM2's Avatar
The timing belt does have an auto tensioner. It is the culprit of many loud *** high pitched noises.
__________________
Old 01-24-2011   #10
Live for the Twisties
MindBomber's Avatar
MindBomber has much to be proud of MindBomber has much to be proud of MindBomber has much to be proud of MindBomber has much to be proud of MindBomber has much to be proud of MindBomber has much to be proud of MindBomber has much to be proud of MindBomber has much to be proud of MindBomber has much to be proud of MindBomber has much to be proud of MindBomber has much to be proud of
+1 the d17 does have an auto tensioner and it does make a high pitched sound when it's going, mine's starting to do it at the moment actually... timing belt time soon i guess.
MindBomber is offline   Reply With Quote
Old 01-24-2011   #11
Whachya lookin at?
BlueEM2's Avatar
Ahh the timing belt have fun with that one. It's a fun job Expect to take a couple days if youve never done it before. Pretty easy though.
__________________
Old 01-25-2011   #12
2001 Civic LX Sedan
Biscuit's Avatar
Quote:
Nathan
Gotta love Honda terminology. It is auto but not hydro.
Nathan
Old 01-25-2011   #13
MindBomber's Avatar
Quote:
I don't have a garage, so I'm debating on whether I'll actually do it myself or just take it to the dealership. The dealership only charges $300 without the water pump and tensioner, so I might just go to work for an extra two days instead and make up the difference in cost that way.
Old 01-25-2011   #14
Whachya lookin at?
BlueEM2's Avatar
Not a bad idea. I don't have a garage either and did the entire job in my driveway, including the head gasket... I recommend doing it yourself if you've never done anything like it because you will learn a lot. I don't know your mechanical experience is the only reason I say it
__________________
Old 01-27-2011   #15
Kevinkriz is an unknown quantity at this point
Mine makes the noise to, really only when it's warming up though around 1-1.5k RPM. I kinda like it, sounds like I got a turbocharger. :P
Kevinkriz is offline   Reply With Quote
Old 01-31-2011   #16
TRUST me! I'm Idiot Proof!
BobDobolina's Avatar
BobDobolina has a spectacular aura about BobDobolina has a spectacular aura about BobDobolina has a spectacular aura about
Props to the driveway mechanic! I remember those days...
And with $300, you could buy ...a rebuilt v-tec head...naw wait, thas me lol
Either way save the dough and learn your car, dont let it learn you.
BobDobolina is offline   Reply With Quote
Old 02-15-2013   #17
jimmyjames1387 is an unknown quantity at this point
I agree with one of the above posts, I had limited mechanical experience and learned a lot through doing the timing belt job. Fortunately I found a post on this forum that took me through it step by step.
If you do it just make sure your timing belt kit comes with a new auto tensioner. Mine didn't come with one and the spring on the old one got bent. I didn't realize it until it was all put together and it started making the "jet engine" noises mentioned above. Replaced the spring and it runs great.
jimmyjames1387 is offline   Reply With Quote
Old 02-15-2013
CivicForums
Honda Civic
Paid Advertisement
Tags
2001 , civic , engine , high , higher , honda , hum , noise , normal , pitch , pitched , sound , sounding , start , startup
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
How to recover your Radio Code.
This girl needs help!!
Ask Me About DIY Stuff V2!
how do you properly reset the ecu
HELP!!!! Car is over heating after thermostat change
Depo LED Tail Lights
DIY: Driver Seat Rock
Door Panel Removal?:
synthetic oil a waste of money?
vBulletin Skin by ForumTemplates.com
Advertising - Privacy Statement - Terms of Service - Terms of Service - Jobs
All Content Copyright 2007 CivicForums.com
Emails Backup
