Wheel Bearing DIY? 2002 EX
Rep Power: 0 Wheel Bearing DIY? 2002 EX
Can anyone point me to a front wheel bearing DIY (with pics)? I did a search and found a couple different threads but not too clear however.
Can I get a new hub with bearings pressed in already? Guess that would be easier.
Re: Wheel Bearing DIY? 2002 EX
The video is called "replacing an accord wheel bearing" you can find it on youtube too.
GL
Rep Power: 0 Re: Wheel Bearing DIY? 2002 EX
Buy the entire hub and press that into the knuckle. Eric the car guy has a great DIY video on this. http://www.ericthecarguy.com/videos/?tubepress_page=4
GL
GL
Im guessing Accord R&R is the same as Civic R&R.
Pretty much, it will get you through the job. I watched the video before I did one of my wheel bearings (01 ex) and it was almost an identical job. You will need a press or access to one to get that hub out. Or you can try to smack it out with something like Eric uses but I have a press so... Good luck!
Let me just revive this thread and just share my experience with wheel bearing. Several DIY's I found indicated using OEM Honda wheel bearing. Of course I decided to cheap out on it and bought a $46 bearing from Pepboys. Its making noise on slight turns now after about a month. Right now I might just look for a used knuckle to put in.
i wasted time and $ by mistakenly buying a hub online..i thought that the bearing was already pressed into the hub from the factory..it was not....the FRONT wheel bearing is sols separately from the hub (at least on a 2001 LX)
Whachya lookin at?
Rep Power: 288 Re: Wheel Bearing DIY? 2002 EX
^ A smart man there... In case you wanted to know how to remove the knuckle... :
https://www.civicforums.com/forums/1...necessary.html
Received 1,440 Likes
Rep Power: 338 Re: Wheel Bearing DIY? 2002 EX
Since this came up, this one will fit well in here:
Whachya lookin at?
They are called "ATE" sold by Canadian Tire obviously in Canada... They work awesome.. grip much better than OEM. I'm just kinda trying them out because I got a great price on them:
http://www.canadiantire.ca/AST/brows...46_ViewDetails
CarStuff
12-06-2020 12:52 PM
