Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen
Sign in using an external account
Register Forgot Password?
7th Gen In the years from 2001 to 2005 Honda released it's 7th Generation Civic. Chassis codes: EM2, ES1, EP3, EU1
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools Search this Thread
Old 08-19-2009   #1
Protan988 is an unknown quantity at this point
Air conditioning gas mileage question
Hey guys I just have a quick question hopefully you guys can answer.
When you have a/c on will it cause you to go through more gas if you set the fan on full blast vs just on medium or low? In my mind I think the compressor has a clutch and as soon as you turn on the a/c the clutch kicks in so that no matter what fan speed the a/c would be the same for gas mileage?
Correct me if im wrong. Thanks.
Protan988 is offline   Reply With Quote
Old 08-19-2009   #2
unTuned's Avatar
unTuned is a name known to all unTuned is a name known to all unTuned is a name known to all unTuned is a name known to all unTuned is a name known to all unTuned is a name known to all unTuned is a name known to all
Send a message via MSN to unTuned
Re: Air conditioning gas mileage question
yea ive always wondered this too and i thought the exact same thing. thats why when i have ac on, its either full blast, or its completely off.
anyone know for sure?
unTuned is offline   Reply With Quote
Old 08-19-2009   #3
Ckutch02EX's Avatar
Ckutch02EX is an unknown quantity at this point
Send a message via AIM to Ckutch02EX
I can't say for sure but it would make sense that the higher the setting the more gas you would use because the compressor is working harder. Think of it like a home ac. You use more electricity if you have it turned to a higher setting. Makes sense to me. Could be wrong.
__________________
Old School
Ckutch02EX is offline   Reply With Quote
Old 08-19-2009   #4
rednwhite04 will become famous soon enough
the a/c on 7th gens and most new cars runs on a magnetic clutch, which causes no resistance= no change in MPG. This was also covered on Mythbusters "windows down or a/c on"
rednwhite04 is offline   Reply With Quote
Old 08-19-2009   #5
Ckutch02EX's Avatar
It all has to do with speed. Your mileage will go down if you use air conditioning below 30mph as apposed to windows down. If your over 30 it's better to use air conditioning however it would make sense that the higher you have it cranked the more gas is used. Thats why you feel a loss power.
__________________
Old School
Old 08-19-2009   #6
batman900 will become famous soon enough
I also wonder this. However I dont think it matters about the speed, if its on then it is using power to cool and "does" effect gas mpg, but the only dif between how hard its blowing is your fan speed, it doesnt have to work harder to cool the air just because the air is being blown at you faster. I also saw the mythbuster episode, they confirmed you lose mpg with it on but that its better to have it on at speeds over 40mph rather than have your windows down, because the wind resistance hurt mpg more than the AC did at that speed and onwards.
batman900 is offline   Reply With Quote
Old 08-19-2009   #7
Ckutch02EX's Avatar
^^^30 40mph. same point. Thanks for the backup
__________________
Old School
Old 08-19-2009   #8
Images: 178
gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute gearbox has a reputation beyond repute
your fan uses more electricity at full power.
__________________
2002 Honda Civic EX Auto
gearbox is offline   Reply With Quote
Old 08-19-2009   #9
lowlife9's Avatar
lowlife9 is a splendid one to behold lowlife9 is a splendid one to behold lowlife9 is a splendid one to behold lowlife9 is a splendid one to behold lowlife9 is a splendid one to behold lowlife9 is a splendid one to behold lowlife9 is a splendid one to behold lowlife9 is a splendid one to behold lowlife9 is a splendid one to behold lowlife9 is a splendid one to behold
good to know. did you see the one were they filterd fryer oil threw a coffee filter and ran it perfectly in a mercedes diesel with no problems.
__________________
lowlife9 is offline   Reply With Quote
Old 08-19-2009   #10
Awjvail is an unknown quantity at this point
So it's more fuel efficient to leave my windows down while traveling under 40mph, and above it is better to have the AC on? Let me get that straight.
Just a question - a lot of the time when I'm traveling on the highway, I like to just have the windows up and have the fan blowing with the AC off - just to circulate some air. Does this affect gas mileage at all?
Awjvail is offline   Reply With Quote
Old 08-19-2009   #11
Images: 178
well yeah it will use power, but prolly not that much. with the fan off and going fast, air still comes thru the vents if you have it switched to fresh air mode. so you may not even need to turn the fan on to get fresh air blowing inside.
__________________
Old 08-20-2009   #12
Lol so nobody has an answer? I know its more fuel efficent to use a/c on the highway buy my question was never answered. Im assuming that it doesnt matter how much the fan is on. It will just use a bit more electricity. I dont even know if that would effect your mpg that much. Anyways can we agree that it wont affect your mpg then if your fan setting is low or high?
Old 08-20-2009   #13
wallydude03's Avatar
wallydude03 will become famous soon enough
Send a message via AIM to wallydude03
Once your ac is on, it is on. It doesnt matter how hard the fan is blowing.
wallydude03 is offline   Reply With Quote
Old 08-20-2009   #14
25+ Years Driving Japanese Automobiles
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
Quote:
Yes, The fan speed has no bearing on how long the A/C clutch stays engaged. The decrease in gas mileage due to the increased current required for the faster fan would be minimal.
CraigW is online now   Reply With Quote
Old 08-20-2009   #15
lowlife9's Avatar
what if your windows are down but you have wind deflectors then there would be little to no drag ??? did the mythbusters test that.
__________________
Old 08-20-2009   #16
unTuned's Avatar
haha this is getting out of hand!
Old 08-22-2009   #17
Atromos is an unknown quantity at this point
Even though the clutch is magnetic, it still steals engine power. Just because it isn't touching doesn't mean there is no force on it (how do you think electric motors work?... magnets).
To answer your question, your A/C may or may not have a thermometer on it telling it when it is at maximum cold and will shut the compressor off until it warms up.... or maybe it keeps running all the time. I know that if I turn on the A/C in my civic to 100%, it's not as cold as 80% so I don't think the compressor has an on/off switch... it's obviously incredibly weak and doesn't cool the car as quickly as a luxury car does. Just put on your A/C and drive 40+, you're worth it ;D.
Atromos is offline   Reply With Quote
Old 08-26-2009   #18
I try to avoid a/c as much as possible I usually get 600-630kms per tank. My fiances mother is down right now and she likes a/c and it has been on almost all the time and i was only getting 500km per tank. Thats a huge difference and that was a fair amount of highway driving too.
Old 08-27-2009   #19
cloud2987 is an unknown quantity at this point
In my class in automotive service my instructor (ASE Master Technician) told us that on most cars if you go over 45mph the fans wont use electricity since the fans will be spinning anyways. So your engine wouldn't have that extra load so your MPG would be more efficient. I don't know for sure if that goes for Civics as well, but it makes sense to me.
cloud2987 is offline   Reply With Quote
Old 08-27-2009
CivicForums
Honda Civic
Paid Advertisement
Tags
ac , affect , air , civic , conditioning , effects , fan , gas , honda , hurt , lose , loss , mileage , performance , speed
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Looking for a 7th gen manual for free? (UPDATED!!!)
How to recover your Radio Code.
This girl needs help!!
Ask Me About DIY Stuff V2!
how do you properly reset the ecu
HELP!!!! Car is over heating after thermostat change
Depo LED Tail Lights
DIY: Driver Seat Rock
synthetic oil a waste of money?
Door Panel Removal?:
vBulletin Skin by ForumTemplates.com
Advertising - Privacy Statement - Terms of Service - Terms of Service - Jobs
All Content Copyright 2007 CivicForums.com
Emails Backup
