| Re: Need helpppp! Please help I simply removed the throttle body, then removed the idle valve from it.
I cleaned the hell out of the throttle body (it was filthy on a 98 Civic) by spraying it with carb cleaner, then using a scotchbrite pad cut in small pieces, then using a cotton cloth (old T-shirt) to wipe the broken up carbon off.
I basically did the same with the idle valve, just used small pieces of scotchbrite/cotton cloth, and moved them around with a small screwdriver to do the 'scrubbing' of every accessible spot.
Put it all back together, and it's run like a champ since. |
