Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 09-30-2009   #1 (permalink)
dspeedcrazy02
New Member
dspeedcrazy02 is an unknown quantity at this point
codes flashing
my car flashed a code that says p1362 which means no signal in tdc 1 sensor circuit.ijust did the timing belt deoes this mean that i set the tdc wrong on the crank or the cam and what does number 1 mean after tdc. To remove this ad, register today for free or log in if already registered!
dspeedcrazy02 is offline   Reply With Quote
Sponsored Links
Old 09-30-2009   #2 (permalink)
Muirsy
Member
Muirsy's Avatar
Muirsy is an unknown quantity at this point
Re: codes flashing
1 prob means cylinder 1 and yeah u might not have lined it up properly
Muirsy is offline   Reply With Quote
Old 09-30-2009   #3 (permalink)
dspeedcrazy02
New Member
Re: codes flashing
i was not sure but i have an unorthadox under drive crank pulley and ther are three lines to go from, the line on the right is big and bold .thats the line i used for tdc.was i supposed to line up tdc in the middle of the three linez.my car wont really go that fast at all and dies out at stop. is that what bad timing does.
Last edited by dspeedcrazy02; 09-30-2009 at 12:56 PM. Reason: forgot specific details
Old 09-30-2009   #4 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: codes flashing
yeah i think the timing is wrong
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 09-30-2009   #5 (permalink)
Muirsy
Member
Muirsy's Avatar
Re: codes flashing
i would say try the middle one... i think the other to r for advancing or retarding ur timing
Old 09-30-2009   #6 (permalink)
dspeedcrazy02
New Member
Re: codes flashing
i just redid my timing belt and lined the drive gear up with the arrow on the oil pump and correc t tdc on cam.after i put the crank pulley back on all tdc is lined up good. i started my car and the same thing no good some how.is it possible that one of either the cam sensor or the crank sensor went out
Old 09-30-2009   #7 (permalink)
gearbox
Super Moderator
Re: codes flashing
its possible the tdc sensor went bad, it is a pretty common problem when doing timing belt change on our cars.
__________________
www.lubecontrol.com
Member 1025782
Tags
2001 , civic , honda , p1362 , sensor , tdc
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Depo LED Tail Lights
Detailed D17 NA Build Research- COMMENT HERE!!!!
Detailed D17 NA Build Research-ideas updated 10/13
Door Panel Removal?:
good websites
k24 supercharged pics
Horsepower increase
DIY: Driver Seat Rock
Storing/Concealing a gun...in a Civic? w/PICS
Updated Pics - Black 02 Civic Bagged
Site Supporters
aluminum radiator
Honda car spoilers
