Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 06-30-2009   #1 (permalink)
batman900
Member
batman900 will become famous soon enough
Ingalls stiffy shakes the car bad with AC on any ideas??
So I have played with the tightening setting a lot and at this point I almost wanna take the darn thing off. When I have it set at very tight my car takes off just fine no jumping & shaking of the engine, same goes for when its set to the softest setting. However on both of those with the AC on I get really violent steering wheel vibrations and sometimes it even rattles my cds in their holder. I have tried to find some middle ground with the setting and that fixes the bad vibrations but then I have the worse problem of the engine jumping and shaking upon take off in 1st gear.
Has anyone installed one of these and found a good setting for it? what number of threads show if you have? I also have my strut bar sitting almost against my SRI "because of lack of space" and it makes them vibrate together to.
Ty
batman900 is offline   Reply With Quote
Sponsored Links
Old 06-30-2009   #2 (permalink)
TRIZ
Hey! Look At Me!! I'm a Supporting Member!!Administrator
TRIZ's Avatar
TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of TRIZ has much to be proud of
Send a message via AIM to TRIZ
Re: Ingalls stiffy shakes the car bad with AC on any ideas??
I dont have a front strut bar on and I dont have any problems with the stiffy when running the AC. Getting the car moving from a standstill gives some viberations of course, but its nothing super crazy.
TRIZ is offline   Reply With Quote
Old 06-30-2009   #3 (permalink)
batman900
Member
How many threads do you have showing? also why no strut bar? Ive been thinking about taking mine off I just hate feeling like I wasted the money.
Old 06-30-2009   #4 (permalink)
unTuned
Super Member
unTuned's Avatar
unTuned is a jewel in the rough unTuned is a jewel in the rough unTuned is a jewel in the rough
Send a message via MSN to unTuned
i also removed my obx racing strut bar as well because it was sitting above my intake and pressed against it. since it stays stationary, and the engine moves on torque, the intake would rub back and forth against it, and when i finally took it off, i had a huge and very deep grind mark on the top of my intake. its almost grinded right through the top of it.
i understand that it kind of sucks to get one and not really end up using it. but its a way wiser bet when you compare that to buying it, using it, replacing your intake several times when it wears them out over and over.
unTuned is offline   Reply With Quote
Old 06-30-2009   #5 (permalink)
batman900
Member
I used the fuzzy side of some velcro strips to put inbetween them and it works to keep them from rubbing eachother down like that but with the torque dampener shaking my car I can still feel them when they bump against eachother.
Off topic but did anyone notice a dif when they put a strut bar in? I feel like my car is more rigid but like it doesnt corner as well in wet weather ect. May just be me tho.
Old 06-30-2009   #6 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
geez i hated that stiffy! and yes i ran it without a strut bar for safety reasons (so the nut threads on properly). it vibrated the whole car all the time even when cruising. total junk of a mod i took off in a couple weeks. yeah the benefits were nice, but i got tired of feeling like i had a 20 yr old car that was rattling and vibrating all the time. and i missed my strut bar cause there was so much play in the steering response. i have the front ES motor mount insert and i still get good results with only 1/4 of the vibration that the stiffy had. i almost cant even tell its there sometimes.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 06-30-2009   #7 (permalink)
baron340
Senior Member
baron340's Avatar
baron340 is just really nice baron340 is just really nice baron340 is just really nice baron340 is just really nice
I've got poly mounts, a torque damper, and the vibration dampers removed from my subframe. The A/C only made it shake a slight bit before I put my strut bar back on. I welded up a mount to be able to use my strut bar and TD at the same time and now it rattles like crazy with the A/C on. Try taking yours off and see if you notice any difference. But it's always going to be a compromise between vibration and stiffness, it's just the way the physics work out.
baron340 is offline   Reply With Quote
Old 07-01-2009   #8 (permalink)
batman900
Member
Darn what a waste, I dont know if I have the tools to take it back off because im in college now and not at my parents house with the garage.
I think ima just try and get this thing off tho because it made stop and go traffic in dallas TX the other day a nightmare, my girlfriend was in the car and it was embarising my car felt like a pos!!
Old 07-01-2009   #9 (permalink)
gearbox
Super Moderator
haha yeah it got to the point where even i could not handle it anymore cause i didnt like driving in it with all the noise and shakes. take it off, at least you can just take the damper off which requires simple tools, then leave the two metal mounts in place (in the small chance that you wanna reinstall it later). but leaving the brackets wont hurt anything.
__________________
www.lubecontrol.com
Member 1025782
Old 07-01-2009   #10 (permalink)
DDragon7
Ultimate Member
DDragon7's Avatar
DDragon7 is a glorious beacon of light DDragon7 is a glorious beacon of light DDragon7 is a glorious beacon of light DDragon7 is a glorious beacon of light DDragon7 is a glorious beacon of light
I have the Damper in there for like 1.5 years already, and I have grown accustomed to it. Also, I also have the front engine mount inserts in and it doenst vibrate that much.
__________________
I <3 My Honda
(Rep Me and I Rep Back)
2001 Civic SiG, 5spd, Eternal Blue, 126k km
www.ottawahondaclub.com - Admin
DDragon7 is offline   Reply With Quote
Old 07-01-2009   #11 (permalink)
batman900
Member
Good to know gear, it will be my project for tommarow morning then, after I get my school refund im just goana get the front ES incerts if they arent to bad like you say.
Old 07-01-2009   #12 (permalink)
gearbox
Super Moderator
just install the front mount inserts and not the rear. so it will come with 4 inserts and only use the front two. that mount is the easiest to take apart and usually the only one to break. im sure yours is broken. but the mounts will fix it back up and will be much less vibration than stiffy. after a while the vibration will go away even more as you break it in.
__________________
www.lubecontrol.com
Member 1025782
Old 07-02-2009   #13 (permalink)
batman900
Member
Just an update, I busted my knuckles like 3 times today but I finally got the thing off and wow my car feels so great now!!! I didnt even remember how smooth it could shift and what it was like without all the vibrations. I can also order and safely install a neuspeed strut bar and get rid of this junky one I have now.
Thanks guys, looks like the answer was tosing this curse off my car all together. Just wish I hadnt wasted the 150$ on it.
btw if anyone wants it ill sell it for 50 bucks plus shipping. Its a bit scratched up on the flat sides and I think I lost a washer when I took it off but other than that its all there and works fine. been used for about a yr & half now, car is just a DD no hard use.
Old 07-02-2009   #14 (permalink)
TRIZ
TRIZ's Avatar
^ good deal, btw- neuspeed only seels the black bar now. I've looked high and low all around the net for the polished one. A few sites have it still listed, but dont realize that its been discontinued. Nobody has any in backstock.
Old 07-03-2009   #15 (permalink)
gearbox
Super Moderator
black ftw! blends into the engine bay like its not there (the yellow sticker can come off too). you will love the neuspeed bar.
__________________
www.lubecontrol.com
Member 1025782
Tags
ac , bad , break , car , cavalier , dampener , damper , engine , ingalls , mounts , poly , put , shakes , shift , shifts , stiffy , torque , vibration
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Depo LED Tail Lights
Detailed D17 NA Build Research- COMMENT HERE!!!!
Detailed D17 NA Build Research-ideas updated 10/13
Door Panel Removal?:
good websites
k24 supercharged pics
Horsepower increase
DIY: Driver Seat Rock
Storing/Concealing a gun...in a Civic? w/PICS
Updated Pics - Black 02 Civic Bagged
Site Supporters
aluminum radiator
Honda car spoilers
