like the title says, i need a beam shot of someone's untouched oem 01-03 headlights shining at a white wall from around 25 ft away. im trying to figure out how the left and right side are supposed to line up and wanna see how it comes from the factory. thanks for the help. if i line up the left cutoffs of each side, the right hotspot is higher up, but if i make them both visually even, then from far away one side looks brighter. so idk how its supposed to be.
__________________
Restore Performance, Reduce Costs www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
Sponsored Links
I will try to get a pic of my 2001 pattern for you.
The OEM headlamp should have had the letters "VOL" or "VOR" on the lens. That is to tell you that the lower beam is to be visually/optically aimed using the left side (VOL) of the beam pattern, or the right side (VOR). If its a VOL lamp, then the cutoff on the left should be aligned to be 53 mm (2 inches) below the center of the lamp, when the vehicle is on a level surface and placed 7.62 meters (25 feet) from a vertical wall, and the beam is projected on that wall. If the lamp is a VOR, then the cutoff on the right side of the beam should be aligned to be the same height as the center of the lamp.
thanks guys, yeah night pics ofcourse lol. and dont take a long exposure so it just shows a white blob. i want details of the beam haha. doesnt have to be a white wall, just some material that you can see the beam clearly. red brick prolly wont work.
falken, this is how i did it, i aimed each one separately using the left side of cutoff (vol in the usa). but then the right side passenger beam looks like its too high because the hotspot is above the left side hotspot. the lights themselves are a very weird design, the left driver side has a huge hotspot and the right side has a tiny one with a small flare on the side. but together they sortof blend together i guess. i dont think the coupe lights are like this but rather both sides have the same normal beam and can be aligned easily.
__________________
Member 1025782
ill see if i can get a couple for you tomorrow night. mind you, ive removed my headlights, cleared them, reinstalled, and i have an hid kit. ive readjusted them though to accomodate my hid kit properly, but the beam patterns are still pretty visible, and are as good as i can get them. i adjusted them taking into account road bumps, distance, up/down hills, etc etc so nobody gets blinded. it might help give you an idea of what youre looking for.
p.s. - arent you already projector retrofitted? why are you messing with your light adjusting again?
went back to stock halogen headlights. hids were too bright and bothering everyone on the road (its very hilly here so it looks like im shining lights into ppls eyes all the time when the car points up). even tho they were aimed properly.
__________________
Member 1025782
