Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 01-10-2009   #1 (permalink)
bobbob2x
Member
bobbob2x is an unknown quantity at this point
Hid Help Relay help (yes I’ve Searched)
I’m trying to install my HID with a relay harness and only one bulb works. I then switched the power wires coming from my relay to the ballast. When I did that they other light work. From that I concluded I’m having issues with one of the power wires, in this case its the one farthest from the relay. When bulb is connected to the bad side it flickers for a sec then nothing. Does any one have a idea of what’s wrong where. Bad ground? (I’m currently have my relay grounded directly to the battery ) To remove this ad, register today for free or log in if already registered!
bobbob2x is offline   Reply With Quote
Sponsored Links
Old 01-10-2009   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: Hid Help Relay help (yes I’ve Searched)
if this diagram doesnt work, somethings wrong with the ballast. make sure you have the ballast hooked up with the proper + and - polarity. it only works one way. also be sure you use at least 14 gauge wire thickness.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 01-11-2009   #3 (permalink)
bobbob2x
Member
All the connections were done right, but it looks like my car didn’t have enough juice to start it up. I started the car then turned the bulbs on and the worked fine. Although once I went to take a drive with them and one side went out. I then got home and inspected it and saw that the light will turn on very dim and then flicker and turn off 30 seconds later. I then took out the bulb and it looks blown. My question is now where should I get a replacement and do companies normally cover these in the warranties?
Tags
flicker , hid
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Depo LED Tail Lights
Detailed D17 NA Build Research- COMMENT HERE!!!!
Detailed D17 NA Build Research-ideas updated 10/13
Door Panel Removal?:
good websites
k24 supercharged pics
Horsepower increase
DIY: Driver Seat Rock
Storing/Concealing a gun...in a Civic? w/PICS
Socal Ach Canyon Run Take 2 June 21, 2008
Site Supporters
aluminum radiator
Honda car spoilers
