Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 12-02-2008   #1 (permalink)
2k1_Toaster
Member
2k1_Toaster will become famous soon enough
2001 EX Steering System Questions
Hello,
I am doing some custom electronics for my car which is no problem, but the mechanics of the car are where I would like some input.
Firstly, what I need is a signal from the car that tells me the current rotation of the steering wheel.
From what I am told, the 2001 EX has HPS Steering, not EPS. I would consider having EPS switched in, and I found a thread someone was offering it for $1000 but that is a little steep. Even the parts were around $450 for the rack, and about $150 in other parts which is a bit pricy for 1 sensor.
So I am needing to find some wire somewhere, (even if it is in the ECU), that reports this.
If no wire exists, then it is plan B, make one! So then it comes down to, where can I get to the actual column to where I could slip a ring on it so to speak from top or bottom I guess.
I dont want to dissassemble things unneccessarily if I dont have to. So if the steering wheel is removed, do I get the physical metal column behind it, or is it capped?
Thanks in advance
__________________
2k1_Toaster is offline   Reply With Quote
Sponsored Links
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Depo LED Tail Lights
Detailed D17 NA Build Research- COMMENT HERE!!!!
Detailed D17 NA Build Research-ideas updated 10/13
Door Panel Removal?:
good websites
k24 supercharged pics
Horsepower increase
DIY: Driver Seat Rock
Storing/Concealing a gun...in a Civic? w/PICS
Socal Ach Canyon Run Take 2 June 21, 2008
Site Supporters
aluminum radiator
Honda car spoilers
