Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 10-23-2008   #1 (permalink)
Geoo
Member
Geoo's Avatar
Geoo is an unknown quantity at this point
question?
i kno dis sounds dumb but are our brake lights on the top or bottom? To remove this ad, register today for free or log in if already registered!
Geoo is offline   Reply With Quote
Sponsored Links
Old 10-23-2008   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: question?
um how about on the sides? oh you mean coupe. its the horseshoe piece in the middle, not the top small turn signal piece.
__________________
________________________________________
Restore Performance, Reduce Costs
www.lubecontrol.com
LC20 - go 10k miles on a single oil change
Go Here For Real Medicine
http://www.youngliving.com
Member 1025782
The DX-Resource
http://bellz.sqweebs.com/
gearbox is offline   Reply With Quote
Old 10-23-2008   #3 (permalink)
Geoo
Member
Geoo's Avatar
Re: question?
ok i wanted to make sure because i just bought 04 05 oem led style so the top led is the turn signal right?
Old 10-23-2008   #4 (permalink)
supafil25
Senior Member
supafil25's Avatar
supafil25 will become famous soon enough
Re: question?
just have someone step on them while you look
supafil25 is offline   Reply With Quote
Old 10-23-2008   #5 (permalink)
gearbox
Super Moderator
Re: question?
no. for the led tails, the top led array is the park/brake. the turn signal is in the middle towards the outside, and the reverse is towards the inside. how do you not know this/? have you never looked at your cars lights? lol
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Old 10-23-2008   #6 (permalink)
2005EM2
My Honda Loves Me ^_^
2005EM2's Avatar
2005EM2 should not be questioned 2005EM2 should not be questioned 2005EM2 should not be questioned 2005EM2 should not be questioned 2005EM2 should not be questioned 2005EM2 should not be questioned 2005EM2 should not be questioned 2005EM2 should not be questioned 2005EM2 should not be questioned 2005EM2 should not be questioned 2005EM2 should not be questioned
Re: question?
haha
__________________
Ron Paul Revolution
I <3 USDM.
I HATE JDM.
2005EM2 is offline   Reply With Quote
Old 10-23-2008   #7 (permalink)
d17civickid
Senior Member
d17civickid's Avatar
d17civickid is a glorious beacon of light d17civickid is a glorious beacon of light d17civickid is a glorious beacon of light d17civickid is a glorious beacon of light d17civickid is a glorious beacon of light d17civickid is a glorious beacon of light
Re: question?
Quote:
horseshoes?? LOL
__________________
Im staying....
NA
d17civickid is offline   Reply With Quote
Old 10-23-2008   #8 (permalink)
supafil25
Senior Member
supafil25's Avatar
Re: question?
lol im more go then show so i havent except i blacked out my tails
Old 10-24-2008   #9 (permalink)
Geoo
Member
Geoo's Avatar
Re: question?
ok now i want to know how to make them work on my 01
http://cgi.ebay.com/ebaymotors/04-05...mZ290262825960
the led only connects to the turn signal...i serched but came up with no results
Old 10-24-2008   #10 (permalink)
gearbox
Super Moderator
Re: question?
you might have to splice wires then idk. top leds are brake, round is reverse, and the other one is signal.
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Old 10-24-2008   #11 (permalink)
unTuned
Super Member
unTuned's Avatar
unTuned is a jewel in the rough unTuned is a jewel in the rough unTuned is a jewel in the rough
Send a message via MSN to unTuned
Re: question?
on your car (01) and my car (02), our brake light is the lower one, and the turn signal is the upper one.
on the 04-05 models, its the opposite. the upper one is the brake light, and the lower one is the turn signal. it looks like these lights are designed for the 04-05 to make it so that the leds replace your brake light.
if youre trying to put them into your 01 civic, you will have to try and connect your lower light harness (brake) to the upper one on this (brake) and then your upper light harness (signal) to the lower area on this one. im not sure how compatible the harnesses on the 04-05 are compared to ours. if theyre not the same, you might have to just go pick up a set of signal and brake light harnesses for an 04-05 and replace yours with them.
in the end your car should have the opposite of what youve always had. you will now have an upper brake light and lower signal.
unTuned is offline   Reply With Quote
Old 10-24-2008   #12 (permalink)
unTuned
Super Member
unTuned's Avatar
Re: question?
your 2nd option might be to get a harness that will plug into the lower section of your new light, and splice the + and - wires from it into your existing turn signals + and - wires.
you can also do the same for the leds but you wont need any other harnesses. you can just splice the + and - wires from the upper led piece into the + and - wires from your existing brake lights
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Depo LED Tail Lights
Detailed D17 NA Build Research- COMMENT HERE!!!!
Door Panel Removal?:
Detailed D17 NA Build Research-ideas updated 10/13
cleaning tinted windows
good websites
k24 supercharged pics
DIY: Driver Seat Rock
Horsepower increase
is it possible to paint your body kit?
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
