Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 08-20-2008   #1 (permalink)
rahenry00
Member
rahenry00 is an unknown quantity at this point
Speedometer Busted
My speedometer and odometer stopped working yesterday and it's pissing me off. My alternator fuse died so I replaced it but still no go. I have a dx to ex exhaust swap and I had to buy o2 sensor extensions. I read on here that crimped O2 wires can cause your speedo to go bad. I found this remeedy on here but I'm a little confused with step #2. Which lighting switch are they referring to?
Try this:
1. Push and hold the trip/reset button.
2. Turn the lighting switch on.
3. Turn the ignition switch on.
4. Within 5 seconds, turn the lighting switch OFF, then ON and OFF again.
5. Within 5 seconds, release the trip/reset button, then push and release the button 4 times repeatedly.
This starts the Gauge cluster self diagnostics.
The beeper will sound, the lights will flash, the LCD will flash, and most importantly, the needles will sweep all the way back and forth. If they/one does NOT sweep properly, replace the cluster.
Is there a specific specific fuse for the odometer and speedometer I should test? I looked in the underdash fuse box but there was no fuse for the VSS, is that fuse somewhere else?
rahenry00 is offline   Reply With Quote
Sponsored Links
Old 08-20-2008   #2 (permalink)
hypnotic20
Senior Member
hypnotic20's Avatar
hypnotic20 is an unknown quantity at this point
Re: Speedometer Busted
My best advice is to check everything
__________________
Homer: How is education supposed to make me feel smarter? Besides, every time I learn something new, it pushes some old stuff out of my brain. Remember when I took that home winemaking course, and I forgot how to drive?
hypnotic20 is offline   Reply With Quote
Old 08-21-2008   #3 (permalink)
rahenry00
Member
I have checked every single fuse under the hood and under the dash. I got the diagnostic to work which is pretty cool btw. I did it multiple times and on some occasions all the gauges will rise, hit about 50% drop back down to 0 then go all the way and back to 0. Is there a reason for this fluctuation? On most occasions though the gauges will just rise 100% then back down.
Old 08-21-2008   #4 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
almost sounds like a loose connection. play with the wires going to the cluster and see if any are loose
__________________
________________________________________
Restore Performance, Reduce Costs
www.lubecontrol.com
LC20 - go 10k miles on a single oil change
Go Here For Real Medicine
http://www.youngliving.com
Member 1025782
The DX-Resource
http://bellz.sqweebs.com/
gearbox is offline   Reply With Quote
Old 08-21-2008   #5 (permalink)
rahenry00
Member
I will do that, I am going to also replace my engine bay ground wires just to be safe. Do the wires for the cluster get loose randomly? For some reason when my o2 sensor failed I got the car scanned and I also got a code for the VSS. But I replaced the O2 sensor, reset the ecu, put in a new alternator fuse, and the VSS code is non existent. So I don't think the VSS is bad, and according the cluster diagnostics the speedo works.
Old 08-21-2008   #6 (permalink)
gearbox
Super Moderator
well its weird, my oil light never worked until i disconnected the battery for some other reason, then it suddenly worked lol. so idk something to try. just open the cluster bezel and see if all the wires look okay and arent loose and everything is mounted correctly.
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Old 08-21-2008   #7 (permalink)
rahenry00
Member
Hopefully it's just a loose connection..I will avoid taking this sucker to the dealership at all costs. I need new terminals and grounds anyway so I have a Thursday afternoon project.
Old 08-21-2008   #8 (permalink)
speedfoos
Post Master General
Pull the clip off the VSS and clean the connections, you may have bumped something. But honestly it sounds like a bad connection at the cluster. Like Steve mentioned, pull the cluster out, check the connections for corrosion. The O2 sensor and VSS sensor should not have anything to do with each other, and you've just got some freak coincidence that it happened at the same time.
Oh, and I'm still thinking about the head!
speedfoos is offline   Reply With Quote
Old 08-21-2008   #9 (permalink)
rahenry00
Member
Clint the head is in the same box it came it, hahaha. Why do cars do this??!! Any some pages on an old thread of how to test the VSS so i will try that when I get home.
Old 08-21-2008   #10 (permalink)
speedfoos
Post Master General
Hang on. I'll pull the diagnostic for the VSS and email it to you.
Old 08-21-2008   #11 (permalink)
rahenry00
Member
Update: This Bitch is fixed. I open the cluster and tightened all the connections. Put on new battery terminals and new grounds. Works like a charm. Clint I left the VSS diagnosis as a last ditch effort and luckily it never came to that, but thx for the pdf though, I will keep it for future reference.
Gearbox and Foos plus 1 for you guys!
Old 08-21-2008   #12 (permalink)
gearbox
Super Moderator
yay sounds good. it always ends up being a bad ground or connection lol
__________________
www.lubecontrol.com
Member 1025782
The DX-Resource
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Depo LED Tail Lights
Detailed D17 NA Build Research- COMMENT HERE!!!!
Door Panel Removal?:
Detailed D17 NA Build Research-ideas updated 10/13
cleaning tinted windows
good websites
k24 supercharged pics
DIY: Driver Seat Rock
Horsepower increase
is it possible to paint your body kit?
Site Supporters
aluminum radiator
Honda car spoilers
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
