Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-05-2008   #1 (permalink)
oddmut
Member
oddmut's Avatar
oddmut is a glorious beacon of light oddmut is a glorious beacon of light oddmut is a glorious beacon of light oddmut is a glorious beacon of light oddmut is a glorious beacon of light oddmut is a glorious beacon of light oddmut is a glorious beacon of light
Send a message via AIM to oddmut Send a message via MSN to oddmut
DIY: Driver Seat Rock
Driver Seat Rocking, How to Fix
Here’s what it looks like when your bushings are busted and cause your seat to rock.
Tools needed:
12mm socket
14mm socket
Flat Head
Philips Head
Parts needed:
Washer A 6; Part number: 90501-S3N-003
Bush A 6; Part number: 90502-S3N-013
Spacer 5 for 2001-2002 6 for 2003; Part number: 90503-S3N-003
First things first, if you have the stock radio make sure you have the anti-theft code for the radio, the write down the frequencies for the preset buttons.
Disconnect your battery and wait at least 3 minutes.
Go ahead and remove the plastic covers from the back and unscrew the bolts (14mm)
Once removed go ahead and remove the 2 bolts from the front.
Tilt your seat forward and push it back to reveal the plugs underneath the seat.
Once it is revealed go ahead and unplug. The gray plug has a little button to push and it removes. To remove the yellow grab the sides and it will slide up and then pop out.
When that is done and seat is removed. Car looks like this.
Here’s my seat out of my car.
Pull on the lever to remove it. Use a flathead to remove the cap of the height adjuster. Use the same flat head to push out the C pin in the adjuster and pull off at same time.
Once off use a Philips head and unscrew the screw.
The plastic piece is held in by a clip at the front, a hook in the middle and a plastic screw like thing at the back.
At this point I have my chair sideways and I remove the 3 nuts and do not discard like the TSB says because you will need them to put it back together. Go ahead and take note of the parts when removed as well as their position as you will replace those parts exactly how it came off.
At this point I removed the nut and the washer. Replaced the bushing. The silver part on the screw is the bushing.
I’ve replaced the bushing and put back the rail ontop. Placed the washer in place and put the nut back on. I have not tight it yet.
Remove the front piece. Replace the bushings in the outboard link.
Place the outboard link back in place. On the left side there is a spacer then a washer. On the right there is just a washer. Screw the nuts back on. If you have the chair on it’s side like how I did. Do not put the plastic piece back on till last so you don’t scratch it up.
Flip the chair over and remove the screw (14mm) holding the seat belt buckle. Careful as there is a collar, spring washer, and toothed lock washer underneath the seat belt buckle.
Flip the seat belt buckle over and out of the way. Remove the 3 nuts.
Once removed go ahead and do the same procedure on this side as done on the other side. The only difference is that for 2001-2002 vehicles the spacer for the inboard link is not put back thus you will have 2 spacers to use for the back screw. That is why I said 5 spaces for 2001-2002 models. 2 spacers on the outside and 3 on the inside.
For the back nut for the 2003 it says to discard the spacer on the back screw, then it says to install 3 spacers on the back screw. At this point you will be short 2 spacers. That’s why I noted earlier to buy 6 for 2003 models. 2 on the outside and 4 on the inside.
Once all that is done, go ahead and put the plastic piece back on on the outside part of the seat. Lever and the adjuster back on.
Once that’s done go ahead and put your seat back in the car. I kept my wires and the clips intact and put it back together the way I took it out like so.
Then I just bolt it all in place. Reconnect the battery.
Turn the ignition switch to ON(II) and check SRS. If indicator comes on for 6 seconds and turns off. You’re good. Stays on check for codes and troubleshoot.
If stock radio put back the anti-theft code in and set back the radio station presets.
Set your clock and any other setting which you had.
Check Step 25 in the TSB.
For 2001 2drs check step 26 in the TSB.
Link for TSB http://www.honda-tech.com/zerothread/2189650
I did this with my phone as my flash light and my camera beside me and the little if none at all light in the apartment garage.
Vwola! No more rocking chair. I know the rocking chair is nice but not in a damn car.
thought i'd take my diy i made and post it here too! I didn't see any diy on it. There is a tsb but diys i find more helpful.
__________________
For Sale
03 Ex Civic 4dr NightHawkBlack (DD)
Body Shop in SoCal - Good friend does my ride!
http://www.np2autobody.com/
oddmut is offline   Reply With Quote
Sponsored Links
Old 02-05-2008   #2 (permalink)
lordhelmet
Platinum Member
lordhelmet's Avatar
lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned lordhelmet should not be questioned
Send a message via AIM to lordhelmet
Re: DIY: Driver Seat Rock
Quote:
Thats great.
Good DIY. Rep applied.
lordhelmet is offline   Reply With Quote
Old 02-05-2008   #3 (permalink)
oddmut
Member
oddmut's Avatar
thank you thank you.
__________________
For Sale
Old 02-05-2008   #4 (permalink)
02BLKCIVIC
Official Rattlesnake Hunter
02BLKCIVIC's Avatar
02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of
sweet!
ill bet your car is an 01
__________________
02BLKCIVIC is offline   Reply With Quote
Old 02-05-2008   #5 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
Good stuff man! I've been rocking away for 3 years now so I may actually fix it now! +1 for you, well done DIY.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 02-05-2008   #6 (permalink)
lordhelmet
Platinum Member
lordhelmet's Avatar
Quote:
Originally Posted by 02BLKCIVIC View Post
sweet!
I bet its an 03!
Old 02-05-2008   #7 (permalink)
speedfoos
speedfoos's Avatar
I'm with Don on it being an '01. I have an '03 and my seats are different.
__________________
www.7thgenhonda.com
Old 02-05-2008   #8 (permalink)
lordhelmet
Platinum Member
lordhelmet's Avatar
Look at his profile. Says 03.
You guys have coupes, Oddmut has a sedan. Could this be the difference?
Old 02-05-2008   #9 (permalink)
02BLKCIVIC
02BLKCIVIC's Avatar
i was just basing it off of his center consol in the 8th pic...
__________________
Old 02-05-2008   #10 (permalink)
lordhelmet
Platinum Member
lordhelmet's Avatar
You could have a point there. I wouldnt be so interested in this normally but class is boring right now.
Old 02-05-2008   #11 (permalink)
02BLKCIVIC
02BLKCIVIC's Avatar
"I have an old center console..."
My Ride
__________________
Old 02-05-2008   #12 (permalink)
oddmut
Member
oddmut's Avatar
i'll burst some of ur bubbles. it's an 03. LOL.
what's rep for? lol.
__________________
For Sale
Old 02-05-2008   #13 (permalink)
Rufus
I drink Windex...it keeps me from streaking...
Rufus's Avatar
Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of Rufus has much to be proud of
Awesome!
__________________
Rufus is offline   Reply With Quote
Old 02-05-2008   #14 (permalink)
lordhelmet
Platinum Member
lordhelmet's Avatar
I'm not going to gloat or anything...
Old 02-06-2008   #15 (permalink)
tred311
New Member
tred311 is an unknown quantity at this point
I have an '03 that I took apart last weekend. I DID NOT disconnect the battery. I just unplugged everything and then plugged it back up when I was done. The SRS light is OFF. It does not light up for 6 seconds. It does nothing. I'm not even sure if I have an SRS light in the cluster. It's hard to tell if it's not lit up. Do I have a problem? Thanks!
tred311 is offline   Reply With Quote
Tags
05 , 2001 , 2002 , 2004 , bushings , civic , driver , drivers , fix , front , honda , problem , rocking , rocks , seat
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Depo LED Tail Lights
Detailed D17 NA Build Research- COMMENT HERE!!!!
Detailed D17 NA Build Research-ideas updated 10/13
Door Panel Removal?:
good websites
k24 supercharged pics
Horsepower increase
Storing/Concealing a gun...in a Civic? w/PICS
Updated Pics - Black 02 Civic Bagged
Site Supporters
aluminum radiator
Honda car spoilers
