Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 02-06-2008   #16 (permalink)
kachunkachunk
New Member
kachunkachunk's Avatar
kachunkachunk is an unknown quantity at this point
Re: Depo LED Tail Lights
Ah, I see, but no polarity problems? I dug up some of your posts on these taillights. I can retrofit my own surefire/guaranteed connections so I too won't worry. To remove this ad, register today for free or log in if already registered!
kachunkachunk is offline   Reply With Quote
Sponsored Links
Old 02-06-2008   #17 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
well just make sure you know which is + and -. i had a hard time getting everything wired because the depo lights wires arent labelled. just go slow and be aware how the stock wires are setup. buy a 12v test battery you can work with if you get lost. and you are prolly gonna want the 8thgen civic EX led top mount light, otherwise it will look weird with the tail leds coming on fast and the top filament slow. everything coming on fast = awesome
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is online now   Reply With Quote
Old 02-07-2008   #18 (permalink)
kachunkachunk
New Member
Haha, hmm. My spoiler also has a brake light bar. That thing is going to have a slight delay as well.
Old 02-07-2008   #19 (permalink)
elianthony
New Member
elianthony is an unknown quantity at this point
I have an '01 black Sedan, interested in these lights as well. I've seen them on ebay as well and was curious how they look on a black Civic Sedan. Any Nighthawk owners have pics with these they can post up?
elianthony is offline   Reply With Quote
Old 02-07-2008   #20 (permalink)
gearbox
Super Moderator
Quote:
no it wont. all spoilers use LEDs so it should turn on fast like the tails.
__________________
www.lubecontrol.com
Member 1025782
Old 02-13-2008   #21 (permalink)
gearbox
Super Moderator
heres a link to buy other than ebay
http://www.autodynamic.com/detail.as...1-4-LED-DP-RED
__________________
www.lubecontrol.com
Member 1025782
Old 02-15-2008   #22 (permalink)
kachunkachunk
New Member
I'll be posting my nighthawk pictures as soon as I get a better idea of how to get these things mounted. They just arrived in the mail today, and it looks like I'll be having some fun removing my bumper and all that jazz. :|
Edit: ha ha, whee, also have to figure out power/RCA feeding. Just got my power/RCA cables for the amp+subs in the trunk.
Old 02-15-2008   #23 (permalink)
Envy
Diamond Member
Envy is a glorious beacon of light Envy is a glorious beacon of light Envy is a glorious beacon of light Envy is a glorious beacon of light Envy is a glorious beacon of light
amp wiring is nothing more than hiding wires. just pull out carpet/interior panels and tuck em under. and WgnrRick has a nighthawk black pearle COUPE with these on them I believe. Find his thread.
Envy is offline   Reply With Quote
Old 02-17-2008   #24 (permalink)
kachunkachunk
New Member
Got the lights fitted, I'll have to find a good opportunity to take the pictures.
I can see what Gearbox was saying when he did his own light fittings. There's a male power plug that goes into the grey adapter/socket which plugs into your trunk cables, and it came out a bit too easily. Not something a little tape won't hold together under bumpy conditions, but even then, the chances of it coming loose are not too high anyway.
It's straightforward, but you have to take off the bumper to get at the bottom tail light brackets if you're working on a sedan. After removing two screws on each wheel well, you have two underneath the rear of the bumper, and two near the trunk under some snap-on covers.
After that, just rip off the whole bumper... takes a little force, you might snap off a few small clips. Spray on some lube that won't damage your paint if you're paranoid.
Pics forthcoming! Sorry, cramped garage and ongoing wiring work = no pictures for now.
Edit: I should mention that if your car is in a region prone to being salted a lot, you will probably have to pull off the bumper instead of reaching up from under the car with a 10mm spanner or socket. The reason is that the bolts will be heavily rusted and if you're like me, you would probably have snapped off three of the four buggers. The bumper and the lights won't need them, but it's still two less mounting points for it (lucky it's light).
Old 02-17-2008   #25 (permalink)
gearbox
Super Moderator
i took out those brackets when i installed mine. no sense even using them if three other bolts will be holding the light.
__________________
www.lubecontrol.com
Member 1025782
Old 02-17-2008   #26 (permalink)
Mr_Plenty
Super Member
Mr_Plenty's Avatar
Mr_Plenty has a spectacular aura about Mr_Plenty has a spectacular aura about Mr_Plenty has a spectacular aura about
I got led tails to and i love them lol not the ricey altezzas tho...And i was the only one on my island with them until some copy cat decived to follow my fashion....
__________________
2002 NHBP HONDA CIVIC EX
Never Complete......
TO DO LIST:
-Strut King Pedals
Mr_Plenty is offline   Reply With Quote
Old 02-19-2008   #27 (permalink)
kachunkachunk
New Member
Sorry man, but until you're designing your own tail lights, I don't think you or we can justify having that kind of mentality.
I need a digital camera or a good opportunity. These things look good on the car, I must say! Also got my subs and amp all wired up, everything's looking good. Just got to install my components and PDX component amp next.
Uh... and dynomat the crap out of this thing. It's vibrating pretty bad in the back. ha
Old 03-09-2008   #28 (permalink)
Dirty4Door
New Member
Dirty4Door is an unknown quantity at this point
pics on black sedan?
__________________
'05 NHBP EX Sedan
Dirty4Door is offline   Reply With Quote
Old 03-26-2008   #29 (permalink)
4drcivic01
Member
4drcivic01 is an unknown quantity at this point
yeah i want to see pics on a black sedan as well. So wait to get the tail lights off you need to take the bumper off as well?? damn that sucks. And after reading all the posts, i wasn't clear...are these LEDs plug in and good to go or they need modification and wiring required? thanks
4drcivic01 is offline   Reply With Quote
Old 03-27-2008   #30 (permalink)
gearbox
Super Moderator
they plug in, but their plugs are not the greatest and two of mine were loose and not getting good contact. so i hardwired directly to stock wiring. yes bumper has to come off, but dont put back those stupid brackets, just remove em so that next time you can slide the light off without removing bumper
Tags
03 , 07 , 2005 , 2008 , black , bumper , civic , covers , depo , honda , led , lights , lx , sedan , tail , tails , work
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Detailed D17 NA Build Research- COMMENT HERE!!!!
Detailed D17 NA Build Research-ideas updated 10/13
Door Panel Removal?:
good websites
k24 supercharged pics
Horsepower increase
DIY: Driver Seat Rock
Storing/Concealing a gun...in a Civic? w/PICS
Updated Pics - Black 02 Civic Bagged
Site Supporters
aluminum radiator
Honda car spoilers
