Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 05-05-2008   #76 (permalink)
bomerman19
Super Member
bomerman19's Avatar
bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned bomerman19 should not be questioned
Re: Detailed D17 NA Build Research- COMMENT HERE!!!!
I definitely would do the timing belt wouldn't worry about the the water pump I haven't seen one go on a honda with less than 200 thousand miles. I would grab a new tensioner cause some times sticking a new belt on the old tensioner will over load the tensioner and cause it to break in a couple weeks had that happen to me
As for sticking in a new cam grab some lock tite and hit that cam gear bolt make sure it's real tight. Also grab some RTV or hondabond and place a little underneath the rocker arm assembly at the ends were it bolts to the head by the cam seal and the seal by the cam gear about by the edges were the valve cover covers over the cam. Note: that it shows you where to put the the hondabond in the shop manual, but when you pull the valve cover you should be able to see where honda put some hondabond in from the factory. If you don't hit those spots you will leak oil from the valve cover. Clint had this problem for a while it was covered in his thread with some pics if you need a better idea of the spots I'm talking about.
bomerman19 is offline   Reply With Quote
Sponsored Links
Old 05-06-2008   #77 (permalink)
02BLKCIVIC
Official Rattlesnake Hunter
02BLKCIVIC's Avatar
02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of 02BLKCIVIC has much to be proud of
thanks
__________________
02BLKCIVIC is offline   Reply With Quote
Old 08-18-2008   #78 (permalink)
hwt101
Super Member
hwt101's Avatar
hwt101 is an unknown quantity at this point
Send a message via Yahoo to hwt101
no new updates since may?
hwt101 is offline   Reply With Quote
Old 08-18-2008   #79 (permalink)
02BLKCIVIC
02BLKCIVIC's Avatar
I have all my parts, just need cash to install and tune.
maybe in a year ill have enough cash to get mine installed...
im fucken poor.
__________________
Old 08-18-2008   #80 (permalink)
bomerman19
Super Member
bomerman19's Avatar
update on my car,
I've taken the stage 2 out and dropped in the stage 3 (sooooooo Much smoother!!!!!!!!, a lot less problems) supposed to have dyno this past saturday but tensioner broke and busted 12 valves rebuilt motor and at the same time did uprated clutch 8.5lbs flywheel and LSD in my old ex trans got it all up and running felt so awesome.
Then something went in the trans yesterday evening so back to pulling the engine again everything should be up and running again soon and my new tune date is Wednesday, September 10
shooting for 170hp at the hubs
Old 08-19-2008   #81 (permalink)
civic-driver
Senior Member
civic-driver's Avatar
civic-driver should not be questioned civic-driver should not be questioned civic-driver should not be questioned civic-driver should not be questioned civic-driver should not be questioned civic-driver should not be questioned civic-driver should not be questioned civic-driver should not be questioned civic-driver should not be questioned civic-driver should not be questioned civic-driver should not be questioned
good to hear you guys are still at it keep us updated... im still waiting on a reply from bisimoto on some details for my A1 camshaft regrind. i have my core sitting in a box waiting to be sent out.
__________________
My N/A research thread:
http://www.civicforums.com/forums/18...10-13-a-4.html
comments and everything else go here:
http://www.civicforums.com/forums/18...ment-here.html
civic-driver is offline   Reply With Quote
Old 08-19-2008   #82 (permalink)
speedfoos
Boosted.......bitch.
speedfoos's Avatar
speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned speedfoos should not be questioned
Hey Paul, Andy mentioned you were having a problem with the OBX LSD. What was it and how did you fix it? I'm looking to get one of these for my car.
__________________
Quote:
Originally Posted by LogicWavelength
This thread (T.E.A.R.S.) was inspired by speedfoos. We all know about his very public and very obscene battle against his car's engine.
There's a good chance that I'm not going to answer your PM.
The Foos' 383 Stroker (and everything else) Thread....(clickme)
T.E.A.R.S. Crew Member #2
My terbow shopping list and tips thread
www.7thgenhonda.com
speedfoos is offline   Reply With Quote
Old 08-19-2008   #83 (permalink)
civic-driver
Senior Member
is OBX making a lsd for our cars now? or is it along the lines of getting a honda fit lsd with a few fit parts?
__________________
Old 08-19-2008   #84 (permalink)
bomerman19
Super Member
bomerman19's Avatar
Quote:
It's the honda fit LSD it drops right in the only thing is that you have to use honda fit bolt because the diff is normal threaded cause of the fit spins in a different direction. were our diff has left hand threaded bolts.
Quote:
I was having problems with fitting the axles in and getting them out. the quaife also has this problem but it does not seem as bad (andys axles are a bitch to get out and you need two people to get them back in). the problem is that the aftermarket diffs are machined tighter than the honda diffs. the honda diffs the splines inside the diff that the axles slide into are tapered so that when you slide the axle in it compress the little c-clip ring and it pops into place. were the aftermarket diffs are not tapered so you have take the ring on the end of the axles and bend it so it is tighter in order for the axles to slip in.
My biggest problem was that the ring caused the axle to get stuck and it would not go in all the way and I couldn't get it out. I had to have my buddy tow it to his lift stuck a 4 foot long crow bar on it started bending the bar. stuck a 1/2 ton spreader on it didn't do anything. I finnaly had to take the axle apart stick a piece of black steel gas pipe in the cup and beet it with a sledge with the spreader in wich cause the ring to do something then hook a slide hammer up to it and it came out.
I had to re-pull the axles today and did not have any problems. My biggest problem is that one of the bearings that holds the diff self-destructed I mean the thing fucking exploded I'll post a thread with pics once I find my camera but man it some gruesome carnage
Old 08-26-2008   #85 (permalink)
d17civickid
Senior Member
d17civickid's Avatar
d17civickid is a glorious beacon of light d17civickid is a glorious beacon of light d17civickid is a glorious beacon of light d17civickid is a glorious beacon of light d17civickid is a glorious beacon of light d17civickid is a glorious beacon of light
Quote:
Originally Posted by bomerman19 View Post
update on my car,
is your head ported? do you have the stock intake mani? what are you tuned with? keep us posted man this sounds very interesting!!
__________________
Im staying....
NA
d17civickid is offline   Reply With Quote
Old 08-27-2008   #86 (permalink)
bomerman19
Super Member
bomerman19's Avatar
Quote:
No I do not have a PnP head I don't have the funds right the moment to drop $1200-$1500+ to get a head pnp'ed. And if I did it it would just be for kicks cause the plans for the car in a couple years would not allow me to run a PnP'ed head.
And No I don't have the piece of shit stock intake mani. I got rid of that a while ago I have the JDM Fabtech N/A Long tube Mani Prototype.
tuned on the only system worth tuning on Kpro FTMFW!!!
Old 09-02-2008   #87 (permalink)
d17civickid
Senior Member
what went wrong in your tranny?
__________________
Im staying....
NA
Old 09-02-2008   #88 (permalink)
02BLKCIVIC
02BLKCIVIC's Avatar
a bearing^
__________________
Old 09-03-2008   #89 (permalink)
bomerman19
Super Member
bomerman19's Avatar
first tranny the bearing was bad and grenaded ate the case the second tranny some grit got into the tranny and ate the second bearing took the case with it the third tranny I got from a junkyard that was grade no broken case and was told worked perfectly did not have second gear(spring ring on the second syncro shaved off) an the fourth tranny well so far it works had to open and close the case like 20-30 times to get the shims right on the input shaft but it works and as of late monday night the car runs. I should be able to make jeff evans dyno tune on the 10th hopefully
Old 01-20-2009   #90 (permalink)
d17civickid
Senior Member
any updates? dyno numbers? anything?
__________________
Im staying....
NA
Tags
build , civic , compression , d17 , d17a1 , dx , engine , gas , gx , na , natural , pistons , setup
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Depo LED Tail Lights
Detailed D17 NA Build Research-ideas updated 10/13
Door Panel Removal?:
good websites
k24 supercharged pics
Horsepower increase
DIY: Driver Seat Rock
Storing/Concealing a gun...in a Civic? w/PICS
Updated Pics - Black 02 Civic Bagged
Site Supporters
aluminum radiator
Honda car spoilers
