| Re: Wiper Replacement WTF??? I could not agree more with post #15. In fact pulling the cover was a useless exercise. Insert a flat blade screw driver into the groove that is perpendicular to the blade and proximal to the cover. Gently twist the screw diver to force the cover in the direction that you would logically pull the cover. The Honda manual then explains how to unclip the blade assembly from the wiper arm.
There must be more that one type of OEM blade assembly (#26) for my 06" Civic EX Sedan because there where no clips to "simply flip up". Instead, the entire blade assembly is covered in a rubberized material. At the end of the blade it is easy to push the rubberized covering up and expose the end of the blade insert. Make sure you are at the end of the blade that says "lock". Grab the end of the blade insert with a needle nose plyers and the insert slides out easily. good luck. |
