8th Gen Honda Civic2006 and up is the 8th Generation Honda Civic. It adds a new look to the Civic line-up. A really smooth front end separates it from previous generations while still carrying the reliability of the Civic name.
Welcome to civicforums.com!
Welcome to civicforums.com.
for real...if you cannot figure this out for yourself dont own a car unless you have money for a mechanic 24/7 standby? lawlz!
Then again, dont even bother trying to figure out how to do an oil change! haha!
not only would that cost more, being a 12.00 blade replacement...
buying the whole thing would cost alot more and no...not easier
cuz then it would mean actually using a tool (open end) and line it
up on the spline.
I have same problem removing the blade cover. No matter how much I squeeze, the thing just won't move. Anyone has any suggestion so I don't break the thing.
I know this is an old thread, BUT, it amazed me at how "Intelligent" the design of this blade was....., so much that when I had to replace my girls Blades, it's clean design stumped me..., so I googled it and ended up here....
Now for starters..., at a glance it is hard to figure out...., and Looking at the DIY by FGCOUPE, sorry bro' but your ability to convey the message isn't clear at all..., After about an hour of trying to follow your directions, attempt after attempt, I decided to just STARE AT IT and figure the $h!t out for myself...
First of all, nothing has to be removed other than the blade insert itself...
The arm is covered with a rubber cover which is ONE PIECE, top and sides. The end of the arm has a SOFT AND FLEXIBLE portion so by simply pulling the end up with your thumb, it lifts to expose the tracks.
You'll feel the softer part of the Rubber arm's end which exposes the track and it will be obvious what to do when you feel it...
Simply Pull out the Old Blade,
Take out the Metal Inserts....
Put the Metal Inserts into your new blades.....
and slide them in...
HERE IS THE COMMON SENSE BUT YET TRICKY PART...!!!!
Look carefully at your new blades, the blades have grooves or guides, whatever you wanna call them that allow the blades to be placed (SLID) into the arms...
ONE END OF THE REPLACEMENT BLADES ARE SQUARE, THE OTHER END IS SHAPED LIKE THE LETTER " I "...
Do not lead with the square end.... it won't cooperate....
The grooves in the sides of the replacement wiper blades DO NOT extend all the way to the "Square" end. (which makes it impossible to load the wiper blade into the arm if you start from this side...)
The grooves in the wiper blade STARTS on the side that Looks like the letter " I " which allows the blade to simply slide into the arm's tracks...
IF YOU TRY TO SLIDE THE BLADE IN BACKWARDS, IT WILL NOT ONLY BE VERY DIFFICULT, BUT YOU WILL RIP YOUR NEW BLADES TO SHREDS AND END UP ORDERING NEW ONES.
Ain't this whole thing funny..???
I couldn't figure it out at first, tried to follow this Thread and DIY instructions...
Wasted an hour and a half trying to understand what you all were talking about...
Stared and fondled the arms and blades until it looked like a felony..
Then found that it was easier to stare at it logically than try to understand what was going on here.....
Hopefully the next person that googles "Honda Civic Wiper Blade Replacement" and ends up here has an easier time understanding how we figured out the Advanced Rocket Science of Wiper Blades - 101.
Wait till ya'll SEE how easy it is to replace these civic wiper blades. It's cheap, it's simple, and it's so dam easy, I feel like an idiot for taking more than 5 minutes of my life to install it...
I needed to replace my wiper blades too - but have the 2008 Civic. It does not have the plastic end caps you mentioned above.
The instruction manual has a very helpful step-by-step to replace, it only took about 10 minutes to have them all done.
I ordered replacement blades online, I believe the total cost per set was 8.50. I used a flat screwdriver to pop up the clip on top of the head/arm, then slid the head down to unhook it, turn and pull off the head. Then you pull the blade out from one end of the head, pull out the 2 metal side supports, put them in the new blade, align the end with the tab catch as with the old ones, then slide the blade back into the head, then reinstall the head in opposite order of removal.
Have had the blades since purchase in January 2008 so wanted to change them prior to more winter here in Michigan.
Wow! I've wrenched on cars for years. I own 2 motorcycles. I grew up helping my Dad in his garage. I have an engineering degree from Purdue.
And I've just given up on replacing the blades.
I bought both replacement blades and replacement inserts online.
I couldn't get the caps off with a screwdriver, etc. All I ended up doing is scratching and distorting the cap and scraping myself.
I then went to see if I could just slide out the insert as described above. However, I couldn't figure out which END to peel back and remove the insert. I was able to peel back the end farthest from the end of the arm. I saw the end of the insert with the I-shape. It wouldn't pull out. It was just stretching. Did I need to pull out from the other end?
So I'm taking a break, enjoying some turkey, solve global warming, and then I'll head back down to the garage and look again.
Looking at the replacement inserts and re-reading OC's post, I figured out that the "bottom" end (the one closest to the hinge point) must be the one with the square end. So pulling back the rubber cover, I can feel the end of the insert (you can't see it when the blade is still attached to the arm since you can't get your head that far down). You have to tug hard as there are some detents somewhere along the insert. However, with the blade still on the arm, I'm not sure I can pull the whole insert out without bending the metal bands along the side of the insert. I'll look later when I'm "rested".
At least my CR-V doesn't have anything this weird.
well i came across this thread googling as well... this POS engineering is pissing me off...not very japanese if you ask me [edit: oh, the blades are bosch. that explains it: unnecessarily complicated german engineering]
the first blade i got with no problem. the second blade took me 15min to get the stupid insert in because it wouldn't glide along the "track" smoothly, no matter which way I tried it. I had to move it like 1mm at a time. and then part of the end piece broke when I tried clicking it down...great.
now I can't get the f'in assemblies back on the wiper arms. the instruction manual says to just slide them in (just like how I slid them out with no problem), but no matter what angle I try, etc. I can't get it to fit in...wtf???
Just a quick note about wiper replacement from my experience. The wipers on my 2006 Civic were shot so I Googled to see the best approach. After seeing a widely mixed response on the difficulty, I decided to call up the dealer and see how much it would set me back to just go there and get it done.
The main points:
1. It's almost certain you only need the rubber wiper _inserts_, not the full blades
2. Most dealers will install them for free
Both inserts together cost me a grand total of $12.60 CDN including tax, and they took it into the bay on a very cold winter day and installed them for free.
15 minutes total from arrival at the dealership. No appointment required.
So if you want a no-hassle, cheap, quick fix, that's what I'd recommend
I have a 2006 EX Sedan, I think that the manual is poorly written regarding the wiper blades, and Honda dropped the ball in designing them.
In taking the blades off, I found that it is more important to pull than it is to squeeze. I had to pull pretty hard. After I was able to get the assembly off, I wen't to O'Reilly's and picked up some Bosch blade replacements. They are WAY easier to install.
