8th Gen Honda Civic2006 and up is the 8th Generation Honda Civic. It adds a new look to the Civic line-up. A really smooth front end separates it from previous generations while still carrying the reliability of the Civic name.
Welcome to civicforums.com!
Welcome to civicforums.com.
I had my 06 Civic Ex in for an alignment and was told by the tech that he could not adjust the rear wheel camber specs because honda made no provision for adjustment to the rear setting other than a toe adjustmet.
Has anyone else had this problem? My rear camber specs are -1.8 and -2.0
degrees. The car feels very unstable and requires constant small steering corrections when on the freeway. All the other cars i have owned have never had this problem . Any help or suggestions would be appreciated.
Sponsored Links
I have had this problem on my `06 LX coupe as well as the `01 LX sedan that preceded it. In my `06, I had Eibach rear camber kits installed at 80,000 mi. These have made alignment to spec no problem. Less expensive products to achieve the same end have since become available. I much prefer Honda's independent rear suspension to the torsion beams found in comparable Toyotas, Nissans, etc. But the necessary modification does put one to an episode of extra expense and trouble when the car ages.
I just purchased an 06 Civic EX coupe with 40,000 miles today and quickly noticed I have alot of negative camber in the rear, maybe as much as 5 or 6%on the right rear. The car is stock and I intend to keep it stock (for now) so who makes an inexpensive fix or bolt kit without having to replace the rear control arms?
I know all this camber will quickly ruin my new tires.
