Aluminum splash shield covering oil pan name?
Rep Power: 0 Aluminum splash shield covering oil pan name?
What is the part name for the aluminum cover or shield that covers the oil pan? A few pins were left off and it was dragging the grade and now all bent up and I want to buy a replacement. What is this part called?
Honda civic 2012 EX
Honda civic 2012 EX
Received 1,144 Likes
Rep Power: 485 Re: Aluminum splash shield covering oil pan name?
Not sure if this is what you're looking for, but I believe you're looking at part #1 on the diagram (technically 3 pieces), labeled as "COVER ASSY., ENGINE (LOWER)" part number 74110-TR3-A10
here's an actual picture of the part in question I found on google images
$120 shipped from hondaautomotiveparts.com
$153 shipped on Amazon prime
He just wants item #2 in the parts diagram above. Yes it's aluminum.
74114-TR0-A00
PLATE, FR. ENGINE COVER (LOWER)
14.57
Might want screws and clips #42 and #43, the panel used 4 of each so looksee what's left on the car.
74114-TR0-A00
14.57
Yeah, I had that posted at first, then I saw that OP said it was 2' x 3'. Part #2 on the diagram is what, 8" x 12" ish? Figured I'd post the big piece. Unless #2 is actually 2' x 3', then I got nothin. I'ts been a hot minute since I've been underneath an 8thgen.
Rep Power: 125 Re: Aluminum splash shield covering oil pan name?
Wow..is that piece missing on my 2007 Civic 1.8 2 door coupe? Know it's been too easy changing oil,filter and transmission oil.
Those covers are standard on 9ths, and earlier hybrids sported them.
I ran over a blowing plastic grocery sack a while back, and when I stopped to check... remembered I now have immunity from bags melted to exhaust work.
Maybe 18" x 18" ?
That car never had one.
