8th Gen 2006 - 2011.
Dealer says 07 needs driver seat airbag
Old 08-25-2016
Carta's Avatar
Carta is an unknown quantity at this point
I brought my son's 07 Civic LX in to the dealer to replace the passenger front airbag as per recall. When the dealer called about completing the recall, they said that they saw an airbag warning icon on. Diagnostics pointed to the driver's seat airbag--and consequently the entire airbag system was deactivated because one airbag showed a failure.
I picked the car up before they got the airbag in and first thing I noticed is that there's no airbag warning icon displaying.
So do I trust that the system is in "fault" as the dealer said or is the dealer not reading the diagnostics correctly? If the icon is off, does it mean the system does not find a fault/failure in the airbag system?
Is there another place that can hook up and read airbag diagnostics? I'd like to verify before I turn over $800 to get it replaced.
Carta is offline
Old 08-25-2016
Re: Dealer says 07 needs driver seat airbag
Correct, no fault at this time.
I'd want to read any stored codes then erase them so you start with a 'blank slate', and just leave it alone until such time as the warning light stays on again.
Post again if/when that happens.
ezone is offline
Old 08-25-2016
Carta's Avatar
Thanks, Ezone. I found several posts about connecting ODB ports 4 and 9 to read the codes--but I don't where the codes actually display. Do you have a suggestion?
BTW: the dealer called to say the airbag arrived this morning but he suggested waiting until the light came on again. He said probably a few cycles of getting in the car, buckling the seatbelt, maybe going through hot/cold cycles, and the warning light would likely appear again.
I would like to read the code for myself, though. Thanks!
Carta is offline
Old 08-25-2016
Reverb2005's Avatar
Reverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of light
You can determine what the code is by viewing the SRS light and how many flashes/pauses it makes when you connect the two lines together. The DIY is here:
https://www.civicforums.com/forums/1...ding-them.html
Click the link IN that DIY post, that takes you to a page with a very good explanation of what to do....
Reverb2005 is offline
mgcivicdriver
Engine start problems
16
12-10-2015 11:58 PM
Youngrob650
11-12-2015 11:01 PM
rojasj
11-12-2015 09:29 PM
ademarco6
11-16-2001 10:19 PM
DJNuTzSaK
11-13-2001 03:27 PM
Quick Reply: Dealer says 07 needs driver seat airbag
