8th Gen 2006 - 2011.
2006 Honda civic EX 4dr wont Start, no Crank either, engineoil,brake,check engine ON
Old 07-30-2016
jmcnroe's Avatar
jmcnroe is an unknown quantity at this point
Did a oil change service at a local honda dealer, battery is brand new, couple of months old, tested it at adancedauto too. Car wont start, just hearing a click, wont crank or turn over. Engine oil, Battery and check engine three lights on and they are steady. What would be the issue ? heading to walmart to get a OBD2 scanner to see if there are any codes that i can read. Whats frustrating is the local honda guy does multi-point check everytime i go there and he said everything looks good, its just couple of weeks ago. Before this no start issue, i noticed the similar issue that it would crank but not turn over but after couple of tries it would just start fine.. should have taken it to the shop without neglecting.
jmcnroe is offline
Old 07-30-2016
Re: 2006 Honda civic EX 4dr wont Start, no Crank either, engineoil,brake,check engine
Forget it, you won't find any codes related to the starter.
DON'T YOU DARE BLAME THAT GUY FOR YOUR PROBLEMS!
Starters can fail without any warning. Nobody can predict that.
Test the starter, see if it is bad.
The starter was working just fine then. This is completely unrelated to the current issue of inoperative starter. The only similarity is the fact there is some problem you don't have an answer for, and now you have another new problem you don't yet have an answer for.
ezone is offline
83rs50
01-14-2016 12:38 PM
rojasj
11-15-2015 06:53 PM
chilling_pete
11-05-2015 10:05 PM
98hondaciviclx
10-30-2015 12:21 AM
trv020
10-28-2015 10:37 PM
Quick Reply: 2006 Honda civic EX 4dr wont Start, no Crank either, engineoil,brake,check engine ON
