8th Gen 2006 - 2011.
service records
Old 12-27-2015
Mikeyyy's Avatar
Mikeyyy is an unknown quantity at this point
service records
The papers i received with my civic show oil and filter was changed and 5 quarts oil and 1 quart zmax stuff put in. I check the dipstick and it's hard to tell where the level is on the orange stick. I used an old dipstick i had laying around and compared to the orange one from car and it's in middle of crosshatch area.
invoice shows 5 0W20B Quaker state Synth
lof drained and refilled oil. replaced drain plug gasket and oil filter. added zmax to vehicle
There's no customer name so It looks to me like it was done after they took it in on trade I guess? is this how they just write it up??
Mikeyyy is offline
Old 12-27-2015
Re: service records
What's your question?
Did you ask the service department that performed the work?
The engine does not hold 5 quarts during an oil change, nor should any additive be used.
The service department may be using 'canned jobs' when creating a work order, thus the blanket use of the 5 quart amount. Our (the shop I work at) oil change job wording says something like 'up to 5 quarts' on the work orders regardless of how much oil the engine needs.
The orange dipstick kinda sucks, it can be quite hard to determine where the level is when you have fresh clean oil in the engine. Did you compare the length of the extra dipstick vs original to make sure of what you read?
I have a length of coat hanger ("calibrated length") with a flattened out end and scored hi-lo marks, painted white for clarity, that I sometimes use as a dipstick on this engine.
ezone is offline
Old 12-27-2015
Mikeyyy's Avatar
Re: service records
It was a broken piece of an old one i laid side by side to see where to hold where it was seated. i'll measure orange one and see about something a lil better "calibrated"
i just wanted to know if that just how some places word there work orders. i'll be doing my own oil changes so that'll be the last time anything but oil goes in it now.
Mikeyyy is offline
jdub122
09-05-2015 09:06 PM
Uan
08-23-2015 03:03 AM
Greenmonster
08-21-2015 07:40 PM
colombianDXcivic
Bolt-on Engine Performance
11-22-2001 03:17 PM
CivicChick2k1EX
South
11-13-2001 10:38 PM
Quick Reply: service records
