Silvania Silverstar ultra 9006 halogen bulks OK to Use?
"Honda - tried, true & tested...!"
my passengers side Low beam headlight bulb light burnt out
I want to use a pair of ULTRA Sylvania bulbs I Looked up the
bulbs on the sylavania silverstar web site and it calls for a 9006
my question is Yes I no they will be brighter than using Hondas OEM
has anyone had any trouble with using Sylvania silverstar ULTRA"s
on there Honda as far as Longevity wise I no the oem bulbs will last
Longer BUT there really just not as bright as they should be compared
to the Sylvania ultras. just wanting Your input before swapping out old ones
for brighter safer night driving.
Super Moderator
Re: Silvania Silverstar ultra 9006 halogen bulks OK to Use?
If you want the safest, brightest light, you should do a retrofit to some HID projectors! Otherwise yeah, they will probably be brighter than your old worn OEM ones, although their slightly yellower light is more visible to the human eye than the whiter light of the Sylvanias. I did a lot of research on headlights
Watch out if those bulbs are higher wattage than stock, you may end up melting connectors....
I've been seriously considering a set of HIR lights
http://www.hirheadlights.com/FAQs.htm
Other stuff to read:
http://www.danielsternlighting.com/t...s/Hid/HID.html
(browse his entire site, this guy knows his stuff!)
http://www.hidplanet.com/forums/
Received 1,144 Likes
Rep Power: 485 Re: Silvania Silverstar ultra 9006 halogen bulks OK to Use?
Though, technically illegal. Installing HIDs in a car not originally equipped with HID lights is still illegal, even if you do it right. Whether or not you do it the right way will determine how much unwanted attention you'll get.
im just looking to upgrade my current oem bulbs that's it,
I seen some old review posts back from 07-2010 how silverstar ultras
lasted 8 months im hoping by today there quality is better Lasting than
that. besides that, I don't see any harm in using them.
fatih717171
07-25-2016 06:22 PM
hayden55
07-08-2015 11:38 PM
