8th Gen 2006 - 2011.
Pulling compressor relay over the winter on 2013 w/climate control
Old 10-02-2015
CraigW's Avatar
The system will engage the compressor regardless of selections made... and likely no hidden procedure to disable it, as in past models I've owned.
Think about pulling the relay....anyone think it will cause issues ?? other then tough to clear some heavy condensation on the windshield at times without engaging compressor.
Love the climate control and want to use it, but don't want compressor cycling.
Thanks !!
CraigW is offline
Old 10-02-2015
Re: Pulling compressor relay over the winter on 2013 w/climate control
Search!!! I found the procedure to alter how the HVAC controller operates in my car when I first got it...
AC is now manually controllable when the defroster is on.
Gotta fly for now
ezone is offline
Old 10-02-2015
CraigW's Avatar
I will do some more looking the 7ths, 8ths, and 9ths all have the disable method available.... but nothing that I could locate on models with climate control.
CraigW is offline
Old 10-02-2015
Didn't realize you have this, sorry.
Put it on a toggle switch?
ezone is offline
Old 10-02-2015
CraigW's Avatar
I vowed on this car to tear nothing apart as in the past (cough, cough, lighted key cylinder and extra interior lighting, variable delay wipers and that damn single wire needed)
I know those relays are in super tight to get out, may see if my mechanic has one of the pullers on hand.
Did some more searching this AM and found little info on disable, was hoping the Acura peeps had uncovered a procedure.
CraigW is offline
Old 10-13-2015
CraigW's Avatar
Found by accident yesterday..... so simple. In manual mode (and maybe in auto as well) simply press the A/C button, and display will then say A/C Off.
I had it in Floor/Def setting and the compressor does not engage now.
Even a blind squirrel.......
CraigW is offline
mrohitredd
40
09-09-2017 12:03 PM
RSJ
08-13-2016 01:06 PM
mjdiaz89
06-21-2016 09:26 PM
RSJ
07-23-2015 11:29 PM
user 84948
Air Conditioning
40
07-10-2015 07:08 PM
Quick Reply: Pulling compressor relay over the winter on 2013 w/climate control
