8th Gen 2006 - 2011.
2009 civic acceleration jerky problem! Please help!
Old 05-10-2015
Marcus2thextrem's Avatar
Marcus2thextrem is an unknown quantity at this point
I have an automatic 2009 civic with 90k miles on it. I bought the car with about 75k miles on it. Ever since I bought it I've had problems as it goes to shift from 1st to 2nd gear. As I accelerate and it goes to shift it gets jerky for a second and then shifts. Any idea on what would cause this? Thanks in advance!
Marcus2thextrem is offline
Old 05-10-2015
CraigW's Avatar
Re: 2009 civic acceleration jerky problem! Please help!
Any record of ATF maintenance being performed ??
ATF fluid look dark ??
CraigW is offline
Old 05-10-2015
Shudder...?
Change trans fluid first, use the correct Honda ATF DW-1. Simple drain and fill, about 3 quarts.
If the shudder does not go away, change the fluid again.
Change the fluid like up to 4 times.
If still present, it may need a torque converter.
ezone is offline
usajags84
05-10-2015 08:11 AM
rcolosi
04-29-2015 07:48 PM
civic_gt
04-19-2015 08:15 AM
dooner24
04-14-2015 07:51 PM
deus-ex
04-13-2015 12:29 PM
Quick Reply: 2009 civic acceleration jerky problem! Please help!
