8th Gen 2006 - 2011.
2009 EX-L - Seat heater quit
Old 11-18-2014
Rodrigo's Avatar
Rodrigo is an unknown quantity at this point
My wife's been complaining that her seat heater hasn't been working right. It's a 2009 EX-L with factory heated seats. I fnally drove it long enough to figure out she's right.
The back still heats. The seat bottom does not. If you go back & forth from driver to passenger side with both seats set on high, the passenger side is much, much warmer than driver.
I'm assuming the heating element/pad has gone bad. But before I go to the (HUGE) hassle of taking the seat cover off I was wondering if there are other points of failure to consider. I'm assuming both back and bottom are on the same fuse, so since the back still warms I think electrical is ok.
So I'm thinking it's a matter of getting the cover off and replacing the heating pad/element. Honda OEM part is over a hundred bucks just for the seat bottom. Any reason I can't just get a new generic and wire into the factory harness?
Any advice? Pitfalls to watch for? Anything more I should do while I have it apart?
All advice is appreciated.
EDIT: The thought struck me -- Can I simply check resistance with my multimeter without taking the seat cover off? Theoretically, the resistance of the heating pads should match if I can compare the passenger side to the drivers side. Or, is the resistance of a heating pad going to be so high it will look like an open circuit on a DMM?
Last edited by Rodrigo; 11-18-2014 at 04:11 PM. Reason: Thought of a followup question
Rodrigo is offline
GotSiR
06-23-2016 04:06 PM
mjdiaz89
06-21-2016 09:26 PM
emich
12-11-2015 12:20 PM
MrOldskool
08-18-2015 09:58 AM
SuperGroove
08-18-2015 07:55 AM
Quick Reply: 2009 EX-L - Seat heater quit
