8th Gen 2006 - 2011.
Valvoline next gen is under spec oil...?
Old 02-18-2014
"Honda - tried, true & tested...!"
brags's Avatar
brags is an unknown quantity at this point
Thumbs down Valvoline next gen is under spec oil...?
found this article on Valvoline next gen recycled oil its under specs
from PQIA that tested it.
http://www.pqiamerica.com/Nov2013/Valvolinenextgen.htm
brags is offline
Old 02-18-2014
Re: Valvoline next gen is under spec oil...?
It's recycled oil. I don't think I would use it in something I care about.
I guess you can add Valvoline to the rather surprising list of oil bottlers that use misleading wording to trick the consumer into thinking it meets the specs stated.
"Meets and exceeds specs!"
Maybe some, but certainly not all of them.
ezone is offline
Old 02-18-2014
brags's Avatar
I was pretty surprised though coming from valvoline I mean yeah I no
its recycled oil. but if it were Wallmart house brand recycled oil I can
understand. but coming from Valvoline.? I will never use there oil that's
for sure. I use Pennzoil Platinum in the civic thank goodness for that.
brags is offline
Old 02-18-2014
but if it were Wallmart house brand recycled oil I can understand.
WHY would that make it any more acceptable?
Valvoline has some good oil. Recycled apparently is not one of them.
Look at the list of oil makers that are now licensed to use the "dexos1" specification name for GM, Valvoline has a few of their products in it. http://www.centerforqa.com/gm/dexos1-brands
Also read about the dexos spec http://www.centerforqa.com/gm/about-dexos
Mobil and Pennzoil were among the very first to blend oil that met Hondas HTO-06 specification.
ezone is offline
Old 02-19-2014
Also, is this PQIA trustworthy? (I personally have not heard of them before.)
Have their findings on this oil been confirmed by other independent sources?
ezone is offline
Old 02-19-2014
CraigW's Avatar
Recycled ?
Most shops dump everything but the kitchen sink into that drain pan.
CraigW is offline
Tedverseti
04-23-2020 01:45 PM
Nalmonte
09-28-2015 01:10 PM
Elciteeve
09-28-2015 12:40 PM
fvckbg
09-08-2015 09:55 PM
thaler4cuse
09-07-2015 08:25 PM
Quick Reply: Valvoline next gen is under spec oil...?
