8th Gen 2006 - 2011.
Help please. How to manually open fuel/gas hatch/door
Old 01-21-2014
pjw73nh's Avatar
pjw73nh is an unknown quantity at this point
Greetings,
2007 EX. Wife just called, she is 60 miles away and needs fuel. First time ever gas door won't open. Bear in mind it is the coldest day of the year here. 5 degrees F. I guess there is a possibility that it is frozen. We had a wet snowstorm two days ago and now it's around zero.
How can I manually open the fuel door? Is there any way to jimmy/shim the latch so it opens (without damaging the car)?
I saw several youtube vids illustrating a cable issue and replacement on earlier generations, but I am not sure that's what it is at this point, and really I just need to get fuel into the car to get her home.
Any suggestions welcome.
Thanks.
pjw73nh is offline
Old 01-21-2014
Re: Help please. How to manually open fuel/gas hatch/door
Have you tried getting a second person to help?
One to PUSH DOWN on the release lever, the other to pry on the door?
I think one can pull down the carpet panel from the side of the trunk area and follow the cable to the fuel door pocket, and figure out how to either release it or remove it completely from the pocket. Sorry, no good pics here, and we don't have big problems with the cable on these cars (not like 7th gens). I can't remember the last time we had to change a cable for this on an 8th gen car.
ezone is offline
Old 01-21-2014
Just got a chance to look at one, it does not appear that this idea can be easily completed.
Sorry.
ezone is offline
Old 01-21-2014
CraigW's Avatar
My 2010 sticks in freezing temps at times....but seems to be already released by lever, just stuck.
And with a little work it opens (after scaring the hell out of me being low on gas)
CraigW is offline
Old 01-21-2014
Prelude Owner
GolNat's Avatar
Maybe a glass of warm water to help melt the ice around the door.
GolNat is offline
Old 01-21-2014
"Honda - tried, true & tested...!"
brags's Avatar
brags is an unknown quantity at this point
Not sure if You got it open by now or not ..? going to sugest using
a blow dryer from Your cars 12Volt power supply warm it up on and
around the door latch.
brags is offline
Old 01-21-2014
pjw73nh's Avatar
Well. I sent all the suggestions off to my wife earlier today. I haven't heard back from her yet. She's not home either. So, either one of these suggestions worked, or she's out of gas with a dead cell phone and no way to charge it.
I am hoping for the former. Otherwise, I may be in deep doodoo...
I'll post an update when I find out what it is/was. Thanks for all the suggs.
pjw73nh is offline
Old 01-22-2014
CraigW's Avatar
Certainly scary when they stick. A rain then freezing could make it tough certainly, but for the most part mine has came loose pretty easy.
CraigW is offline
Old 01-22-2014
pjw73nh's Avatar
Hi Folks,
She made it home safely and with a full tank of fuel. It was in fact as many of you mentioned, simply frozen. She was able to have a co worker pry the hatch open with a popsicle stick while pressing on the lever. I may try some of that graphite liquid lube on the latch when I get a chance and see if that doesn't prevent further issues. Though I suspect it was just a "perfect storm" combination of the wet, heavy snow and the rapidly falling temps.
Thanks again for all the help.
pjw73nh is offline
Old 01-22-2014
Honda Chick
PuterChickFL's Avatar
PuterChickFL is an unknown quantity at this point
Glad she is home safely
PuterChickFL is offline
97-DX-Lover
06-14-2015 06:07 PM
darwin-t
04-18-2015 09:29 PM
Gunner
Engine DIY
10-06-2012 12:37 PM
Grey
16
01-27-2002 11:34 PM
CiViCPrAnInG2k1
11-01-2001 03:47 PM
Quick Reply: Help please. How to manually open fuel/gas hatch/door
