car heating slightly when moving slowly ?
Rep Power: 0 car heating slightly when moving slowly ?
Hi I have a 2006 Civic FD1 LXi, lately I have noticed that the car engine heat indicator raises more than half when moving slowly in traffic [its always less than half], its like moving up and down after sometiome over and over again but not all the time, just when the car moves the bar goes down suddenly, its only happening lately ?
anybody knowing where the problem is and whats the solution before i hit the garage?
Thank YOU
Thank YOU
Rep Power: 0 Re: car heating slightly when moving slowly ?
So the car is on brake hold in traffic for sometime, the level might go up [might, because its not happening all the time], then just as the car mores for 3 sec or more the level drops suddenly to the normal level, then again only comes up when and slowly moving in traffic...
Checked, Radiator, Coolant levels...the only thing I can understand is that cable monitoring this level might be malfunctioned, as the level fluctuates for like less than 10-15 sec only...
Received 1,440 Likes
Rep Power: 338 Re: car heating slightly when moving slowly ?
is the rad fan coming on? (there's two, one for the AC, so best leave AC off to check for fan)
Question, do both the fans need to be running, even if AC isn't running ?
From what I know, no, only 1 should be running, I'll check that out..
Thank you
The AC system can turn them on, and high coolant temperature can also turn them on.
Yes sir, I did check that radiator level all are showing upto the mark..
Just making sure we're clear on this.
If the radiator is low, and you have the 1.8 Liter "R" type engine........start looking for leaks.
A change of one or two light segments might be within reason, but it should stay in the middle somewhere. The "gauge" you see on the dash is heavily buffered by the computer, the middle of the light set could be anywhere from ~170 to 220*F (76-105*C).
Both radiator fans run at the same time when they are turned on.
I know you stated this, but it sounds to me like you meant you checked the white plastic reservoir. You need to open the radiator cap and make sure it is full too.
I'd use a scanner to read live data from the PCM, read the engine coolant temperature and see what is going on there when the gauge changes on the dash.
Thank You All
but when I run the AC both fans turn on,
The PCM operates the fans based on either of two inputs:
The PCM decides to turn them on low speed when it sees a valid AC request and engages the AC clutch relay, High speed comes on at 221 PSI AC high side pressure,
and the PCM turns them on high speed when the coolant temperature is sufficiently high enough to require them (my info says 206*F/97*C).
The only way I can think of to obtain any more vehicle info is with a scanner that can read the ECT #1 (engine temp) and ECT #2 (radiator temp on our 8th gen and newer cars), along with Fan operation command data from the PCM. Same scanner should be able to operate the fans upon user command too.
You said it is fairly cold there, you may have not waited long enough for the PCM to see a need for running the fans. It can take a loooong time, and if there is any breeze the fans may not be needed at all.
I'd say to fix the leak and keep the radiator full.
Then recheck if the fans run or not. Do not rely on the dash gauges. Monitor coolant temperature on a scantool while waiting for the fans to come on.
or a scan plug to phone. or a scan gauge
Amazon.com: BAFX Products Bluetooth OBD2 Scan Tool for Check Engine Light and other Diagnostics - Android Compatible: Car Electronics
cooldan1
04-23-2015 10:49 AM
civic_gt
04-19-2015 08:15 AM
Civic4ever1996
04-16-2015 08:30 PM
dooner24
04-14-2015 07:51 PM
