8th Gen 2006 - 2011.
2006 Civic Trunk Release w/Car Starter?
Old 12-18-2013
Burdzy's Avatar
Burdzy is an unknown quantity at this point
Hi,
I just had a compustar Remote Starter installed in my Wife's 2006 Honda Civic. When I "remote start" the car, the Remote Trunk Release stops working, both from the computstar Fob AND from the Honda Key Fob. I was told from the place that installed the starter, that it is a Honda limitation that when the car is started, Honda and Acura cars disable that functionality, and they can't do anything about it. 2 Questions:
1. Does this sounds correct? Does Honda disable the Key Fob trunk release when the car has been started?
2. Does anyone know of a way to over-ride this?
Thanks in Advance!
-Burdzy
Burdzy is offline
Old 12-18-2013
Re: 2006 Civic Trunk Release w/Car Starter?
Let's see if you can answer your own question:
Start the car with the key, and then try the remote functions.
You should have your answer in 30 seconds or less.
ezone is offline
Old 12-19-2013
CraigW's Avatar
I would almost bet it IS inhibited via micu.
CraigW is offline
Old 12-20-2013
Prelude Owner
GolNat's Avatar
I tried this on my wife's TL. Trunk wouldn't open when the car is started with the transmitter button.
You could wire the trunk release from the remote start into the inside trunk release button as a work around.
GolNat is offline
Xuhme
21
08-07-2023 03:40 PM
carhag2000
04-25-2015 01:33 PM
cperez53
04-16-2015 09:31 PM
gabrown2
04-11-2015 08:22 PM
Elusiv1
11-08-2001 09:55 PM
Quick Reply: 2006 Civic Trunk Release w/Car Starter?
